Parts express sells the scosche cable for $1.59/ft, but you will get raped on shipping. Around $2 would be my guess.
To do list: 1. 4 ga. ground wire 2. speaker wire (what gauge should my speaker wire be?) 3. Head Unit....I swear to god im going to kill myself over this
HELLO HELLO HELLO!!!!!! did you guys miss my first post? the kit has a 4-8awg distro block!!!!! enough wire for a main run, then to 8awg they also give you 8awg for ground..... he doesn't need the 4awg ground unless he's ditching all the 8awg and the distro block.... in which case, you get a lot of crap you don't need, you could probably get separately for cheaper qqqqqqqqqqq
ok im going to try my best to explain it..... these people keep telling you that you need a 4awg ground instead of 8awg...... that is not true you have a main run of 4awg which goes into a distro block the distro block changes the wire size into 8awg (supplied in kit) which goes into your amp. whatever goes into your amp should be whats coming out of your amp....... so you have a run of 8awg ground wire (supplied in kit) the only reason...... that you WOULD want to get the 4awg ground....... is if you're only running a single amplifier. IN THAT CASE, you have no use for the distribution block, nor the 8awg runs of wire...... if that is the case, you will probably be better off getting your own wire, and putting your own connectors on the ends of it B) make sense?
yes it does. I will only have one amp so I guess I do need the 4 ga. ground. How much would all the wires, connectors....etc cost? I payed 25 for this kit. If its only a 10 dollar difference It doesnt really matter to me.
In that case, all you need is a short run of 4awg ground wire...... shouldn't be too expensive, as you're supposed to keep it under 2 feet, but i keep mine under a foot if possible. Even at a dollar a foot, its not bad..... Then again, all you need is a single set of RCA cables, a long enough power wire to get to your amp plus an extra foot for ground, and the connectors.... could be less than 25 bucks. Hmmmmm if you already have the wal mart kit might as well keep it in case you decide to get another amp later on..... is that 4awg run going to be long enough?
I did not see a 4ga. kit or a hang tag for it......I will go back and check. If not I will keep the kit and get 2ft. of ground wire and 10 ft of speaker wire........that sounds about right?
Get yourself a shit load of speaker wire, not just what you will need. That way when you get another amp for the front you dont have to go running back to the store. Unless you think you will loose the wire.
ok im going to try my best to explain it..... these people keep telling you that you need a 4awg ground instead of 8awg...... that is not true you have a main run of 4awg which goes into a distro block the distro block changes the wire size into 8awg (supplied in kit) which goes into your amp. whatever goes into your amp should be whats coming out of your amp....... so you have a run of 8awg ground wire (supplied in kit) the only reason...... that you WOULD want to get the 4awg ground....... is if you're only running a single amplifier. IN THAT CASE, you have no use for the distribution block, nor the 8awg runs of wire...... if that is the case, you will probably be better off getting your own wire, and putting your own connectors on the ends of it B) make sense?[/b][/quote] no in in truth he still needs a 4ga ground and another Dirtibution block If you have a 4ga main feed, going to a 2way distirbution block, to 2 amps then you need to run 8ga back to another distrbution bock and then 4ga to a SINGLE grounding point you dont want mutiple ground points it you can aviod it, it could cause noise but in this case he does not need a muti-amp kit, so they one has too much wire so instead of buying more wire, he could (like sandt said) run 2 runs of the 8ga (the kit has 6ft you should not need more than 2 for each run) but the kit is fine and who ever said take it back because he bought it at walmart COME ON, hey I have some oxygen free wire to sell you :lol:
no in in truth he still needs a 4ga ground and another Dirtibution block If you have a 4ga main feed, going to a 2way distirbution block, to 2 amps then you need to run 8ga back to another distrbution bock and then 4ga to a SINGLE grounding point you dont want mutiple ground points it you can aviod it, it could cause noise but in this case he does not need a muti-amp kit, so they one has too much wire so instead of buying more wire, he could (like sandt said) run 2 runs of the 8ga (the kit has 6ft you should not need more than 2 for each run) but the kit is fine and who ever said take it back because he bought it at walmart COME ON, hey I have some oxygen free wire to sell you :lol:[/b][/quote] in truth mike you are right, BUT the purpose of that particular kit was to run a separate ground to a single point otherwise he'd have a 4awg ground and a distro block instead of the 8awg ground wire....... I have piggybacked grounds on a single point plenty of times and had no problems with it at all. regardless...... im just telling him how it will work based on what the kit gives him...... B)
I gave the kit back, bought a 8 guage kit for the HU which has been used to put in the Alpine and ordered a 4 guage KnuKonceptz kit for my amp. The Scoshe kit did well for the 7893 install. The SQ is amazing with this deck.......I have been deproved all my life...lol. One question......the unit is set to auto dim which is supposed to work once my headlights are on but for some reason the thing doesnt dim. I can dim it manually but it doesnt do it automatically. Dont know why......oh well The Unit was basically new. It had the warranty card, instructions and everythign else. It was never installed either.
