which sub is better out of these ones..?
Discussion in 'Car Subwoofers' started by ferrari-f50gt, Jan 30, 2008.
  1. ferrari-f50gt
    ferrari-f50gt Full Member
  2. electrolytic
    electrolytic Full Member
    Which amp is good for that sub you mean? lol Both would work, just not sure about running the cheaper one @ 1 ohm, someone here must know HiFonics, if you can safely!!
  3. electrolytic
    Can this be run at 1 ohm without it blowing up, anyone have experience with these?
    Hifonics BXi 2006D
    2000-Watt Brutus Mono Amplifier
    * RMS @ 4-Ohm: 1 x 650-Watt
    * RMS @ 2-Ohm: 1 x 1300-Watt
    * RMS @ 1-Ohm: 1 x 2000-Watt
    * Hifonics New Illuminated Heat-Sink Design With Blue LED Light Pumps
    * Hifonics Blue Illuminated Logo
    * Maxxsonics Illuminated "M" End Panel Logo
    * Heavy-Duty Ultra-Fi™ MOSFETS
    * Highly Efficient Super D-Class Amplifier Circuitry With Oversized MOSFET Output
    * Fully Adjustable Accu-Cross™ Crossovers
    * ±18dB Variable Bass Equalization @ 45Hz
    * 180° Variable Phase Control (15 to 35Hz)
    * Dash-Mountable Bass Remote Control Included
    * Variable 24dB Subsonic Filter
    * Brutus Pulse Wave Modulated MOSFET EXVP (Exponential Vari-Power Supply)
    * Twin-Turbo Torroid Coil Design
    * HSMD Hifonics Surface Mount Design
    * Balance Line Inputs for our 18-Volt Line Drivers
    * RCA Line Output for Amplifier Daisy Chaining
    * Gold Oversized 2-Gauge Power Connectors
    * Power From The Gods Included
  4. electrolytic
    Look at all the new people in the last 24 hours LOL wow, all those KicKeR threads must be paying off!!
  5. G3n3R@1
    G3n3R@1 Full Member
    haha i noticed the exact same thing. perhaps the enclosures as well!
  6. cccullen
    LOL. I noticed that last night (my time). There were a lot of new people online
  7. electrolytic
    Sure, have a party without me!!
  8. fstrfvo
    fstrfvo Full Member
    Yes those Hifonics amps will run 1 ohm without any problem. I have a 1206D pushing a dual 2 ohm coil 12 inch L7 at 1 ohm and I have a Titan 1505D pushing 2 PPI DCX 124's at 1 ohm. They barely get warm and have never shut down or gone into protection. If you have the money look at the Earthquake PHD 5000, that would be killer on the stroker sub.
  9. electrolytic
    why does my orion get so hot lol, i'm only running 2 ohms, can image if i tried 1 ohm..
    EarthQuake Amplifiers @ LightAV.com 877-390-1599 Earthquake,phd,mono,sub,block,2,4,5,ch,channel,2000,5000,10000,w,ph,1000,1500,2200,w,.2,.4,300,600,900,.5,tnt,phd2,d,3,4,class,d,spl,record,Earthquake,phd,mono,sub,block,2,4,5,ch,channel,2000,5000,1000
    Earthquake PHD5000W
    3000 RMS @ 2 Ohm Monoblock Amplifier
    Number of channels: 1
    Max Power output: 5000W
    RMS Power 2-ohm: 3000W
    Damping Factor: >800
    Cross over slopes: 24dB/OCT
    THD: >0.016
    SNR: 104dB
    Dimension: 2 1/2" x 10 1/2" x 15"
    FEATURES
    * Mono block - single channel amplifier
    * Built-in variable low pass-filter
    * All time low-pass operation
    * Two independent low level RCA inputs
    * 180-degree variable phase shift
    * Heavy duty custom power connection
    * 8-gauge speaker connection
    * 0-gauge power connection
  10. cccullen
    fstrfvo, you should post some pics. I'm just curious, you're using focals for you seps, 2 L7's and Hifonics amps? That's something I'd like to see. That must be crazy loud!
    I finally went with the 1206d and i'm going to use a 15" L5 i'll just run it a 2 ohms. I also got the zxi6406 for my DLS seps. I've been hearing that Hifonics don't run hot. Can't wait to get it installed...
  11. electrolytic
    so, what are we at ferrari $1000.00 will get you something SICK!! lol so much for your $500-$600 budget
  12. electrolytic
    Yes, pics pics...
  13. fstrfvo
    fstrfvo Full Member
    Let me clarify, My wifes car has 1 12 inch L7 pushed by the 1206D with a eclipse 4 channel pushing Fosgate fanatic Q in front and Oz Audio 6x9 in rear deck with Alpine head unit and XM satellite radio. My car has Focal polyglas 6 1/2 inch in the front doors (165 V1) and 5x7 in rear deck (570 CV1) with a 4 channel Hifonics (ZXI3406) with 2 Precision Power DCX 124's pushed by a Hifonics Titan 1505D amp at 1 ohm.
  14. cccullen
    gotcha, be nice to see how you set it up. I'm trying to get some ideas on how i'm going to do mine.
    If you could post some pics, that would be great.
  15. electrolytic
    pics, pics lol
    Ok, how about this lol, maybe someday...
  16. electrolytic
    And this!
    XX MAXXIMUS AMPLIFIER
    1 x 10,000-Watts RMS @ 2-Ohm
    2 x 5,000-Watts RMS @ 1-Ohm
  17. fstrfvo
    fstrfvo Full Member
    Hey Electro have you looked at the Boston SPG 555 subs? They have soft part system which allows you ro replace the cone/surround and spider assembly at home. It also has removable voice coils so you can change it out if you want to change impedence or burn it out. A guy I know has some in his f350 truck and they are sick lous but also are so musical its crazy. If I had the $$ id buy some but they are a little out of my range.
    CC you have a ford like me so you probably have 6x8 cutouts in the door. I just used the factory mounting spots for my speakers. In my cars when you get the top sound system ford had tweeters in the sail panels in the doors and mid woofers in the 6x8 holes. I just used the same mounting points with a little quiet cote sprayed around the mounting holes. Nothing much to see but its functionial and sounds great. What size speakers do you have in the rear??
  18. fstrfvo
    fstrfvo Full Member
    I just read that you bought a 1206D going to a L5 15. All I can say is that my 1206 pushes my 12 inch L7 pretty hard but no where near its limits, mine could use a lot more power for sure but my wallet cant afford a bigger amp. What does Pedro run on his Kickers??
  19. cccullen
    Choices are vary scarce here in the philippines so I had to use DLS 5 1/4's seps in the front and DLS 5 1/4 in the rear doors as well. They don't sell 5x7's or 6x8's here. I'm really disappointed with my lack of mid bass. I want to get ride of my DLS 5 1/4's in the rear and put something else. I'm still figuring out what to do. any ideas on what i should put in the back doors?
    The only model they sold at the time was the XLT 4x2 model which is the base model with the air suspension. So the sound system wasn't great and unlike yours, mine didn't come with the tweets in the sail panels.
  20. cccullen
    Pedro is only running i think 250 watts but he hit a 135.8 @48hz(burp) and took 1st place in his class Iasca & Db drag. He's got 1 L5 10" and He's using PG 2 M50's but his gain is almost at zero and bass setting on -15.
