JBL W12GTI SUBWOOFER 12" 4,000 Watt Differential Drive® Design Subwoofer THIS JBL W12GTI IS BRAND NEW AND IN THE BOX. KEY FEATURES OF THE JBL W12GTI ARE: • Suggested Retail Price: $599.00 • Differential Drive® Design (DDD) motor • Die-cast vented basket • Kevlar®-impregnated paper woofer cone • Nitrile-butylene surround • Power handling RMS: 700 watts • Power handling Peak: 4,000 watts • Cut-out diameter: 11" • Mounting depth: 10-1/4" • Sensitivity: 91dB • Dual 6-ohm voice coils Sensitivity 91dB @ 2.83V/1m Power Handling 700W RMS, 4,000W Peak Frequency Response 18Hz ~ 1kHz Impedance 3 or 12 ohms Voice-Coil Diameter 3" (76mm) Mounting Depth 10-1/4" (260mm) Overall Diameter 12-1/4" (312mm) Cut-Out Diameter 11" (280mm) Displacement 0.149 ft3 (4.23 l)
lol, bastard! but that's a little excessive, it makes no sense. I'll leave you's alone now lol. This is more believable to me. * Dual Gap Technology uses a short voice coil and two magnetic gaps to create extremely high excursion with lower mass * Oversized ellipsoid surround and clamping system creates larger piston area * Heat sinking frame for better thermal performance and higher power handling * Dual Gap Motor Design * Surround Clamping Ring * Spider Clamping Ring with Integrated Speaker Terminals * Axial Edge Surround System * Field Replaceable Re-Cone Kit * Power Handling (MAX) : 4000 watts * Power Handling (RMS) : 2000 watts * Sensitivity: 84 dB 1w/1m * Mounting Depth : 8"
Boston Acoustics GT-24 - 2-Channel High Current Amplifier • 300W RMS x 2 @ 2 • 900W RMS x 1 @ 2 • Adjustable Mounting Feet • Screw-Down Security Cover • 2 Ohm Mono Stable • Continuously Variable Crossover and Q - , Car Amplifiers, 2-Channel Amps - So Alpine MRP-M850 - Alpine 1 Ch 1500 Watt Digital Power Amplifier Kenwood KAC-9103D - Kenwood 1 Ch 1800 Watt Amplifier
Ok, but what's up with that JBL sub, it has dual 6 ohm coils and sucks lol. For the same price and cheaper you can get these. Cerwin Vega Stroker 124 Subwoofers Kicker 06S15L7-4 Subwoofers PPI PRO104 Subwoofers
that cerwin sub isnt bad but what about for an amp for it and im trying to stay under 500 or 600 dollars for the whole system (the amp, sub, and wiring kit) also that kicker isnt bad either but i dont really wont a kicker cuz i see everyone with them
maybe this, and run at 1 ohm, that boston acoustics amp looks descent too Cerwin Vega Stroker 102 Subwoofers Hifonics Txi 1508D Amp: Mono
lol, oh man i think i'm changing my mind from cerwin vega to MA Audio for my subwoofer... MA Audio HK15X2 15" 4000W Dual 2-Ohm Competition Subwoofer * Sensitivity: 90.6 dB * RMS Power Range : 2000 Watts * Peak Power Handling: 4000 Watts * Impedance: 2 Ohm * Diameter: 15 Inch Features * 2000W RMS * 4000W MAX * Sensitivity: 90.6dB @ 1w/1m * Mounting Depth 9 3/8" * Mounting Diameter 14.2" * Vented Box: 5 cu/ft * Port: 48 sq/in 13.0" Long * Sealed Box: 2-2.5 cu/ft * Dual 2 Ohm * Aluminum Round Wire Voice Coil * Hi-Temp Kapton Voice Coil Former * 400 Oz. Double Stacked Strontium Magnets * Patented Thermo-Cooling Motor Structure * Bumped Back Plate for Max Excursion * High Roll Triple Layer Ribbed Surround * Double Layer Progressive Spiders * Dual Layer Pressed Carbon Fiber Cone * Ultra Strong Carbon Fiber Dust Cap * Rubber Sealant Gasket
MA is decent...that sub won't handle 2000 watts daily but it'll handle some decent power A shop around here used to sell those subs....until they closed because they sucked and no one ever bought anything. lol they were called "Stuntin' 101". Super gay. There were all these crappy cars riding around town with their "Stuntin' 101" sticker on their cars but all they had was a crappy deck. ****ed me the F off lol
ok thanks lol, i've searched a bit and most people say it's good for spl but not so good SQ. Do you think that cerwin vega stroker will handle 1800-2000 watts daily?
Hey Ferrari i found a sweet deal, complete, amp, two subs and 4 gauge wire kit. Let me know if you want the link. TOP OF THE LINE PACKAGE SYSTEM FOR SOUND QUALITY AND POWER! PAIR OF KICKER 12" SOLO BARIC 06S12L5-4 SUBWOOFERS TOTALING 2,400 WATTS MAX AND 1,200 WATTS RMS PLUS HIFONICS BXI1206D 1200w RMS MONO AMP + 4 GAUGE PHOENIX GOLD AMP KIT, FREE REMOTE BASS BOOST CONTROL INCLUDED. $529.00
