which sub is better out of these ones..?
Discussion in 'Car Subwoofers' started by ferrari-f50gt, Jan 30, 2008.
  1. ferrari-f50gt
    ferrari-f50gt Full Member
    ok so you think it should all work then
    and do you know where i can get some damping material for cheap
    or where i can get some good 0 gauge or 4 gauge wire for cheap
  2. jayz85
    jayz85 Full Member
  3. jayz85
    jayz85 Full Member
    if you buy the wire make sure to use 'wiresale' as the coupon code during checkout. for 40 percent off.
  4. ferrari-f50gt
    for the big three would i be ok with 4 gauge wire
  5. electrolytic
    electrolytic Full Member
    ferrari the combo your talking about is 1600 watts at 1 ohm? That amp can pull 120 amps if i remember correctly
  6. ferrari-f50gt
    i used the formula that is posted on the page befor this and thats what i got for the answer
  7. electrolytic
  8. electrolytic
    I would definetly try, it's a nice setup. Do the wiring solid and it might be ok.
  9. ferrari-f50gt
    yea thats what i thought and if its to much for my system i can aways go down to 2 ohms instead of 1 ohm but i was seeing if i would be ok with useing 4 gauge wire for the big three
  10. aznboi3644
    4 gauge wire for the big three is perfectly fine.
  11. fstrfvo
    fstrfvo Full Member
    I did the big 3 with 4 awg wire and my stock alt is 130 amps. My Hifonics Titan amp is supposed to do 1500 watts at 1 ohm, my lights just dim slightly under heavy bass notes. You should be fine, at least try it out first before spend the cash on a new alt.
  12. ferrari-f50gt
    ok good cause that 0 gauge wire is like 5 times more expensive then the 4 gauge wire
  13. ferrari-f50gt
    yea my alt is pretty good size already its 120amps
  14. fstrfvo
    fstrfvo Full Member
    but I did run 0 guage from the battery back to the amps, which is about 18 feet. the big 3 was 4 gauge.
  15. fstrfvo
    fstrfvo Full Member
    so after all this what amp and subs did you decide on??
  16. electrolytic
    1600 watts is going to want some serious juice, i would do 1/0 gauge wherever possible. Your gonna need all the help you can get. Even if your car has a big alternator, unless it was changed, it will only have enough power for the car, the manufacturers won't put more than is needed to run the car so you will be pushing it.
  17. electrolytic
    I just made a small upgrade in the back to some 1/0 gauge and the few pieces i changed made a huge difference. Now i can play like 8 songs cranked before both batteries start dying, where before i could only play like 2 songs when it was 4 gauge in the back connections. It's like getting free extra power!
    The 4 gauge i have going to the back will soon be changed to 0 gauge also. My car originally had a 70 amp alternator and i upgraded to a 130 when i got the car. Trying to make it work lol.
  18. fstrfvo
    fstrfvo Full Member
    Hey electro what kind of car do you have, it looks very familiar?
  19. fstrfvo
    fstrfvo Full Member
    ok I looked at your photos, 96 Taurus. That was our first Taurus, Had Orion Extreme 6.5 comp in the front doors and I think Fosgate 6x8 in the rears with a Lightning Audio 4 channel amp. Mtx thunder 2100 pushing 1 12 inch Boston pro sub, Panasonic HU. Pretty loud but those Orions sounded a lot better than I thought they would. Wife got ran over by a semi truck than hit by a dodge ram on the 605 freeway. Everyone survived without a scratch so she wanted another Taurus. She still drives a 2000 Taurus with 110,000 miles. They jacked everything in the car when it went into impound, all they left was the Boston pro, go figure the easiest thing to steal and they left it behind.
    Is That Orion amp is that power hungry that you need 2 batteries, man whats the fuse rating on that beast??
  20. ferrari-f50gt
    yea but iam gonna have to try and make the 4 gauge work cuz the 0 gauge is to much money for me right now unless you can find me some good 0 gauge for abou the same price as 4 gauge or like around $50 or $60
