SoundStorm 2F2200 Amp: 2-Channel OR Lanzar MXA252 Amp: 2-Channel OR Lanzar OPTI2X300D Amp: 2-Channel are any of these any good
I'd still take this over those, better company. Lanzar is cheesy lol. Hifonics ZXi 6006 Amp: 2-Channel Hifonics ZXi 6006 2-Channel 1200-Watt A/B-Class Zeus Amplifier * RMS Power Range : 150-600 Watts * Number Of Channels: 2 * Maximum Power: 1200 Watts * Built In Crossovers: Yes * Channel Separation: Yes Features * RMS @ 4-Ohms: 2 x 150-Watts * RMS @ 2-Ohms: 2 x 300-Watts * RMS @ 4-Ohms: 1 x 600-Watts * Crossover And Switching: o Variable 12dB Octave Hi-Pass o Variable 24dB Octave Low-Pass o ±18dB Bass Boost at 45Hz * Inputs and Diagnostics: o Variable Input Level Control o Power and Diagnostics LEDs o DC Short Circuit Protection o Over-Load Protection * Connector Types: o Unbalanced Inputs (RCA’s) o Full-Range Line Outputs (RCA’s) o Molded 4-Gauge Power Inputs o Molded 10-Gauge Speaker Outputs
for the price this is a deal.plenty of power. your choices are of cheap....well...... not good quality brands for the type of abuse i'm sure your going to give them.
i know i said i didnt really want a kicker but i think i like these one but i wanna know if this combo is any good and what you guys think of it
i was thinking that i would have to run them at 1ohm but idk which one would work the best and would it change the spl or the sq for 1ohm or 2ohms....?
That set up will pound like crazy. I have 1 12 inch L7 and it shakes the car like crazy but its no where near its limit, it could use more power but I dont have the cash to buy a bigger amp. No big its in the wifes car anyway. As for 1 or 2 ohm thats a good question, when I went to a local high end shop to look for the clean sweep I told him how my system was setup, and he told me to rewire my subs to 2 ohm instead of 1 ohm. He said much better sq and very little power loss. Remember the rule is you have to double the power to get an increase of 3db. Not much difference, but 2 ohm might be easier on you electrical system. Im curious to see what eveyone else has to say on that one. Hey CC did you get your sub and amps yet??
They were delivered to the pad in cali already. I won't get my hands on them til the end of the month. I HOPE. I have to ship em over here now.
hold on lol, what happened to your budget? This combo seems a little off to me, the subs are only 600 watts rms and your amp is capable of pushing 1700 watts i think. Did your budget change?
ok, that's an awesome deal on the amp, get that for sure but the subs, i'd go with at least the kicker L7 subs they are rated at 750 watts rms i believe, you can get two dual 4 ohm subs and run that amp at 2 ohms. It will be sweet. The L5s are nice but they are a little weak and can't take much abuse. You should be able to find a deal on two L7s at around the same price. Hifonics BXi 1606D Amp: Mono
an increase of 3 db is going to be twice as loud.so there is a diff there. i think for the SQ thing.it has to deal with the amps ability to control the sub at lower loads(damping factor).most amps have better control on the sub at higher loads i.e 4 ohms. it would depend on the amp.the higher the damping factor number the better.also it would be less strain on your elecrical at 2 ohm mono over 1 ohm mono. case in point.i need to to something with my power situation now that i have 2 amps running 2 ohm mono since i added another sub. before; i must have been just at the wires ability to supply the current needed to my amps.
i guess it changed a little but not really cuz iam still trying to stay at $500 or less and the combo that i posted was pushing that $500 price well i liked the look of the 2008 L5s that i have posted and you said they are weak.... what is it that they did to the L7s that made them stronger and then the L5s
just the power rating L5 is 400 or 500 watts and the L7s are 750 watts rms. Will handle more power, i'm sure hifonics is a bit underated so it will probably push more than it says. The L5s i must have went through 4 or 5 of them, fried most, sold the rest lol. Go for the stroker and the hifonics it's the best deal i can find. The stroker is only $200-$220 then you can run that amp at 1 ohm. Dual 2 ohm subwoofer.
hmmm, that amp has Fuse Rating 160A (80A x 2) lol so it is a beast, you may need an alternator upgrade. Hifonics BXi 1606D Brutus Series Class D Monoblock Amplifier (BXi1606D) Replaces BX1605D 1-Channel Mono-Block Operation 1100 watts RMS x 1 chan. @ 2 Ohms / 1600 watts RMS x 1 chan. @ 1 Ohm Super D-Class Topography Ultra-Fi MOSFET Outputs Illuminated Hifonics Logo PMW MOSFET EXVP (Exponential Vari-Power Supply) SPC Twin Turbo-Torroids with Simpatico Coil Design Fully Adjustable Accu Cross Crossover Includes: 24 dB Subsonic Filter (Adjusts 15 Hz - 50 Hz) Bass Boost: Variable Bass Equalization (+18 dB @ 45 Hz) Remote Bass Control Included Balanced Line Inputs with Optional Hifonics MM-BLD-1 Gold RCA Line Outputs Permits Amplifier Daisy-Chaining 4 Gauge Power Connectors Dimensions: 13.77"L x 10.39"W x 2.63"H 1-year Sonic Electronix warranty Amplifier Specifications: Amplifier Class N/A Number of Channels 1 - Mono RMS Power (4 ohms) 550 watts x 1 channel RMS Power (2 ohms) 1100 watts x 1 channel RMS Power (1 ohm) 1600 watts x 1 channel Bridged RMS Power Not Bridgeable Peak Power Output N/A Minimum Impedance Unbridged 1 ohm Minimum Impedance Bridged Not Bridgeable ohms THD at Rated RMS Power <0.1% Speaker Level Inputs Yes Preamp Outputs Yes - 1 pair Built-in Crossover Yes - LP High-Pass Crossover Frequency N/A Low-Pass Crossover Frequency 35 - 250 Hz Subsonic Filter 15 - 50 Hz Signal-to-Noise Ratio >95 dB Channel Separation N/A Bass Boost 0 - 18 dB Bass/Gain Remote Yes Fan Cooled N/A Fuse Rating 160A (80A x 2)
