would this amp be able to handle two of these subs...? Cerwin Vega Stroker 122 Pair 12 Inch Subwoofers 4000 Watt Subs Dual Voice Coil 2: Compare Prices, View Price History and Read Reviews at NexTag MTX TC8001 Thunder 2400W Amp Mono Block Amplifier: MTX TC8001R REFURB AMPLIFIER CA V1 TheDeepDiscount
i liked your eD combo, exact same setup my friend has in a 4cuft box tuned to 30hz. **** slams really hard. surprised the hell out of me i've never heard a setup with 2 12s that gets that loud.
that cerwin vega sub deal says pair of subs but it's $218.00 each sub, just wondering if you knew that.
MA AUDIO ? 1800 watts rms with the cerwin vega, more power more power lol MA Audio HK2000D Amp Class D 1 Channel Mono Block 1800 Watt RMS Amplifier Digital Car Audio: MA Audio HK2000D AMPLIFIER CA V1 TheDeepDiscount
You just need to make up your mind on how much you want to spend? Find an amp and subs that fit within your budget and go for it. What about alpine type R or X series. Oz Audio Matrix elite subs, soundstream also makes good subs and amps as does Boston Acoustics. Precision power, Orion and Crossfire also make good amps and subs. Theres lots to choose from but only you can make the choice.
MTX TC8001 Thunder 2400W Amp Mono Block Amplifier: MTX TC8001R REFURB AMPLIFIER CA V1 TheDeepDiscount 1 of them Diamond Audio D312D2 - D3 Series 12" Subwoofer • Dual 2 Ohm • 800W MAX • 400W RMS • Thick Wall Proprietary Frame • Venturi Vented Basket • Aluminum Dust Cap • Shallow Mount - , Component Subwoofers, 12" Component Subwoofers - Sonic Electronix 2 of them OR MTX TC8001 Thunder 2400W Amp Mono Block Amplifier: MTX TC8001R REFURB AMPLIFIER CA V1 TheDeepDiscount 1 of them Kicker 05C124 - 12" Component Subwoofer • 150W RMS • 4 Ohm • Vacuum Formed Polymineral Cone • Double Stitched Polyfoam Ribbed Surround • Ultra-Length Voice Coil • Rear Cone Brace - , Component Subwoofers, 12" Component Subwoofers - Sonic Electronix 4 of them OR MTX TC8001 Thunder 2400W Amp Mono Block Amplifier: MTX TC8001R REFURB AMPLIFIER CA V1 TheDeepDiscount 1 of them Kicker 05CVR122 - 12" 800 watt Component Subwoofer • Dual 2-ohm Voice Coils • 400W RMS • Polymineral Injection ISD Cone • Stamped Steel Basket • Ultra-Length Voice Coils • Rear Cone Brace - , Component Subwoofers, 12" Component Subwoofers - Sonic Ele 2 or them would any of these be good set ups with good spl and sq (more spl tho)
You really want that mtx eh lol, they are nice but more pricey than others that can do the same wattage or more and it is refurbished so your taking a chance on how long it will last. It says 2400 watts max but you have to look at the rms output of that mtx amp, that's the true power. At 2 ohms it will push 800 watts rms so if you do get it, try and match that to your subs rated rms within 50-100 watts probably would be best. * 1 MTX TC8001 Class D Mono-Block Amplifier * 1Channel Mono Block Amplifier * Class D (Patented Adaptive Class D) * Power Ratings * 2400 Watts Max Power * 2 O 800 Watts x 1 RMS Channel and <1% THD+N * 4 O 400 Watts x 1 RMS Channel and <1% THD+N * Signal-To-Noise Ratio (1 Watt) 75 dB * THD+Noise (Distortion) (1Watt) <0.25% * Frequency Response (-3dB) 20Hz-200Hz * Maximum Input Signal 5V * Maximum Sensitivity 100mV * Low Level Input * Hi-Level Input w/ Smart Engage Auto Turn-on * Low-Pass Crossover 40Hz-200Hz, 24dB * Subsonic Filter 30Hz, 12dB/oct * Thunder EQ 0-18dB, Freq. 40Hz * Remote Level Control Subwoofer (Parallelable) * Full 90 Day Warranty * Manufacturers’ Suggested Retail: $599.99
Those kicker cvr12s are nice subs too i have the same, they pump!! They will take some abuse too lol.
somehow i dont think that mtx box does those kickers justice, youuu should build a nice new perfect box as designed by the man AZN!
no its just one of the amps i saw that use under $200 but it you can find me one that is better and that puts out more power let me know thanks
here's a descent 800 watt amp from the same guy, and maybe two kicker cvr12s MA AUDIO MA Audio HK598 800 Watt Amp 4 Channel Amplifier 2 Ohm Stable Stereo: MA Audio HK598 BRAND NEW AMPLIFIER CA TheDeepDiscount * MA Audio HK598 Amp * Power Output 800 Watts * Power Output 4 X 400 Watts @ 2-Ohm * Power Output 2 X 400 Watts RMS Stereo @ 4-Ohm * Platinum Plated Connections * Quiet Fan Cooling System * High Quality Power & Protection LED's * Thermal / Short / Overload Protection Circuitry * 0-18 dB Variable Bass Boost * 40-250Hz Variable High Pass Crossover * 40-250Hz Variable Low Pass Crossover * THD @ 4 Ohm <0.05% * THD @ 2 Ohm <0.01% * S/N Ratio >90dB * Channel Separation 60dB * Frequency Response 20-20kHz * Input Voltage Range 200mV -4V * Input Impendence 10k Ohms * Dimensions (H x W x L): 2.7” x 12.4”x 13.7” * 2 Year Warranty * MA Audio Suggested Retail $499.99
electrolytic are both of those kicker subs i post good and then wat about the diamond subs and how do they compare to eachother
7000 WATTS RMS LOL MA Audio HK10KA 10,000 Watt Amp HK-10Ka Digital Amplifier 1 Channel Mono Block 7000W RMS Car Class D: MA Audio HK10Ka AMPLIFIER CA TheDeepDiscount
The yellow ones are a bit weak, but the red ones the cvr12s are strong subs and they sound nice. Sorry i don't know about diamond audio.
haha ya i may do that for my cerwin vega stroker, i have a good ported design but was thinking maybe t-line. These kickers i'm selling, they are on ebay right now for $150.00
