so you say i diffidently need another battery with a 200 amp alt....... and were you saying you found that ported was the best...?
yes, yes and yes lol you might be able to get away with say a 120 or 130 amp alternator with a solid big 3 in 0 gauge and another battery at least but that amplifier must pull 100 amps easy. So i would go for a 200 amp alternator, it's also not a good thing to starve a big amp like that for power. There is a good place on ebay for the 200s i can give you the link if you want.
That's on my list too don't feel bad lol, i already upgraded to a 130 alternator but it's not enough for my orion, i'm going for a 200 amp alternator and a hc2000 kinetik battery for the back, i have a 1200 cca battery in the front and i have 1/0 gauge wire but i haven't installed it yet, too cold out.
This is pretty well what i have, an older pic , with a 130 amp alternator 1200 cca battery in the front big 3 with 4 gauge mind you but it's not enough and the wire needs to be changed to 1/0 gauge and a 200 amp alternator. Lol it's adding up quick, hopefully when mine is done i can just enjoy it problem free for years lol.
.............................kicker------cvr12 Also i'm only pushing just over 1000 watts rms 2 ohms bridged mono
Specifications Theile Parameters Brand: Cerwin-Vega Model: Stroker Pro 15 MSRP: $1,699.00 Warranty: 1 year parts and labor MECHANICAL SPECIFICATIONS Weight 68.3 lbs. Rear Mounting Clearance 9.75” Woofer Magnet Dim. (dia. X ht. in mm) 260 x 20 x 2, 200 x 20 Voice Coil Diameter 100mm (3.93”) Voice Coil Winding Layers 2x2 (two, two-layer coils) MEASURED T/S PARAMETERS Nominal Impedance (ohms) 4 Revc (ohms) 3.65 (both 1.83-ohm voice coils connected in series) Sd (cone area in square meters) 0.087 Bl (motor strength in Tesla Meters) 22.2 Vas (in liters): 40.0 Cms (micrometers per Newton): 37.4 Mms (grams): 468.1 Fs (Hz): 38.7 Qms: 4.47 Qes: 0.83 Qts: 0.70 POWER AND EXCURSION DATA Sensitivity (2.83V/1M in dB): 86.1 series/92.1 parallel Continuous Power Handling (watts RMS): 2,500 Peak Power Handling (watts): 5,000 Xmax ([coil length – gap height]/2 in mm): 38.6 COMPUTER SIMULATION DATA Enclosure size for simulation (cubic feet) Sealed: 2.7 (0% fill) Vented: 3.0 (0% fill) tuned to 36Kz -3dB (F3) at 2.83V Sealed: (Qtc=0.93): 43.0Hz Vented: (Qtc=0.93): 43.0Hz Voltage to achieve Xmax + 15% Sealed: 150V Vented: 126V SPL at Xmax + 15%: (36.8mm) Sealed: 126dB Vented: 128dB
do i need or is an isolator good to have with two battery's 200 Amp Chevy Battery Isolator Stereo Cole H NEW 48162: 48162 DB Electrical Starter-Alternator
you shouldn't, my buddy has a stock chevy bat up front and an optima yellowtop in the back connected with 0 gauge in parallel and its just fine.
hey, i'll paste my message here too, so others can chip in. Re: alternator if one battery is bigger than the other battery or a different age then the lower one could draw from the bigger one and kill them both. That might take a month or so i'm not sure. but they say if you buy two new batteries the same at the same time then that won't happen. I can't afford 2 new kinetiks so i'll see what it does to my car in the next few days i will know. you can get a pac 200 relay from ebay cheap or i can sell you mine if your worried about it. but i need to see if i'm ok without it first lol. give me a few days. __________________ i removed my relay today, hopefully my car starts tommorow lol
ok and then another thing what if i just switch my battery out with a heavy duty yellow top and do the big three with 0 gauge and then up my alternator to a 200 amp one.......would that work
