which sub is better out of these ones..?
Discussion in 'Car Subwoofers' started by ferrari-f50gt, Jan 30, 2008.
  1. G3n3R@1
    G3n3R@1 Full Member
    regular 12v computer fans will do the trick.
  2. ferrari-f50gt
    ferrari-f50gt Full Member
    hey if i built a box for the sub and a place the amp can sit on the box. how or what would be the best for the cerwin vega stroker pro 15in and how much cu. ft. would i need or should have for that sub
  3. G3n3R@1
    G3n3R@1 Full Member
    azn is your man! man does he have is work cut out for him. he just finished cccullens box and now hes designing a 4th box for me. a tline for a polk GNX124
    GNX124 Car Subwoofer from Polk Audio
  4. electrolytic
    electrolytic Full Member
    Ya, Azn hurry on, work to do.. People are waiting.... hahahehe I keep telling you start charging, at least $20.00 make it worth your while. Then it doesn't seem so much like work lol.
  5. electrolytic
    A quick call to Cerwin-Vega got me to Bob Diamond, CV's senior design engineer. He recommended I use a sealed enclosure with an internal volume of 2.7ft3 for the best overall sound quality. Jayson Olson, master installer at Speaker Works, was enlisted to build this special enclosure. The enclosure would be constructed out of two layers of 3/4" MDF with internal bracing to add strength and minimize flexing of the enclosure walls.
  6. G3n3R@1
    G3n3R@1 Full Member
    now thats how you get a box that small to weight over 100lbs itself!
  7. cccullen
    I can get them here for dirt cheap. I guess its better to be safe than sorry.
  8. G3n3R@1
    G3n3R@1 Full Member
    i would recommend 120mm fans due to the fact that they can rotate more slowly to move more air and therefore quieter, not like that'd be an issue anyways;)
  9. aznboi3644
    Sh!t i really need to get my paypal account up...the most I would charge for a design is $10 if it is for a more complicated and bigger design. If it is something simple probably just $5
  10. ferrari-f50gt
    so you say i should use a sealed box not a ported box......
  11. G3n3R@1
    G3n3R@1 Full Member
    im sure they used sealed to not only make it simple but to make sure it sounds good and has precision. im sure with a sub that beastly you could do a tline or ported box that would still sound good and be loud as hell
  12. aznboi3644
    depends on the parameters if it will sound good in a t-line...ported i'm not sure. It should be built for ported because its a fukin beast
  13. ferrari-f50gt
  14. fstrfvo
    fstrfvo Full Member
    CC if you have them in a false floor go for the fans, mine are mounted on the back of my rear seat which is open to the trunk. I have driven from So cal to Vegas many times which is like a 3 1/2 hour drive and they barely get warmer then ambient air temp. They really do run very cool and I listen to a lot of music that has a lot of bass, 50 cent, kane west etc etc. But if they were in a false floor without a lot of airflow they might get warm. Just put the fans in a push pull configuration, so you have 1 blowing cool air in and 1 blowing the hot air out, just like when you build a computer. Try and have the incoming blowing over the heatsinks if possible.
  15. cccullen
    got it. man, I gotta a lotta building to do now. this is going to be fun. This weekend i'm pulling down the headliner and door panels to insulate them. I'm gonna try to get everything done before my stuff gets here.
    I very familiar with so cal, my family has a condo out in Lancaster. Vegas isn't so far away. I should go with the fans here, the temp in so cal and here are VERY different. The amps may get a little hot here especially in a false flooring.
  16. electrolytic
    You will probably need another battery in the back along with the 0 gauge big 3 and probably a 200 amp alternator. That's a lot of wattage, if the earthquake is anything like my orion which i'm sure it is they are extremely power hungry. Umm just wondering about the earthquake amp, i'm unfamiliar with it, seems a little too cheap for the amount of power it's rated. Any comments? If it's between a descent Hifonics or Earthquake which would be better. They are roughly the same price range.
  17. fstrfvo
    fstrfvo Full Member
    If both were the same price id go with Earthquake, but they are usually more expensive.
  18. electrolytic
    ok, do you a good place online?
    Hey ferrari, that was a quote i copied from the review of the cerwin vega stroker pro. I'll probably do mine ported, will have to see what bassbox says. I think i ran it through before and ported it was pumping!!
    Azn, charge $25.00 each design, seriously man don't sell yourself short. Do the boxes you promised already for free but seriously dude!! Each design would take at least 2 hours to input the specs and then run it through every way possible to get the best response. $5.00 or $10.00 is too cheap, people will think they are not getting anything special for that amount anyways. It's a lot of work and it's high tech work, they will pay for your knowledge not how long it takes you. Back me up someone...You can have it all azn..."if you build it they will come" lol
  19. pedro quiroga
    i'm sure you can even make some money building boxes at home too.
    i know you do some boxes,but if more people knew.....
  20. electrolytic
    I did run it through bassbox before, found the files. This is for a 12" stroker pro, ported, give you an idea anyways. 141 db without cabin gain..
