Just to give you a comparison, my old Tantrum 1200.1 amp required an inline fuse of 80 amps and it pushed out about 1520 watts rms. So I doubt you'd need an inline fuse much more than that for your amp that pushes 1800 watts rms. I honestly think a 100 amp fuse would suffice given what other similar powered amps require.
Is it possable to hurt the amp by getting too low of a fuse? say 100 if it needs 120. would it fuck it up?
Fusing your 4 awg wire protects your wire, not the amp. This is the way I understand it. Also, seeing your amp has fuses installed in it, you should be fine.
so, if you put to low of a fuse it wont carry as much power as needed. if this is the case i could just try various fuses to see which one works. Im assuming it uses more power when you turn it up as well. so i could find one that will atleast play it, then go up one or 2 sizes.
Too large of a fuse, and you risk not protecting what's supposed to be protected. In the case of an underhood (or in this case, main power wire) fuse, that's the wiring and the car. In the case of amp fusing, it's the amp componentry. Too small of a fuse, and you risk popping it during normal operation, when there is no danger. That's no fun, just annoying.
I think a 120 amp fuse on the 4 awg wire going to your sub amp would be a good size to use. It's clearly not too large and it shouldn't be too small for that amp. If that is too small (which I highly doubt it would be), then just bump up to the next available size.
I just got a response back from audiobahn, and they basically said the same thing geolmon said. "The way to figure out the max amperage draw of any system you need to add up the fuse ratings of all of the fuses in all of the amps that will be connected to that power cable." Since my amp has 5 30 fuses, the max total for just this one amp would be 150. However, can 4 guage safely consistantly handle 150? Do I even need to worry about that since I would not be running it at its max?
In YOUR case - 4 gauge probably can - but that's only because your total wire run here is only going to be something like 4 feet! However, the wiring between your ALTERNATOR and the battery in the back has to be considered, since this will be the main supplier of current! So, this likely will need to be 1/0, even with the battery relocated to the back - the battery isn't your current source.
James, geo is talking about upgrading your "magic 3", not replacing any wiring. It is pretty easy to do and well worth the effort. There is a good tutorial over at Sounddomain's forums about this: http://forum.sounddomain.com/forum/ultimat...ic;f=5;t=007801 Also, just because I am ignorant, is your battery in the back of your car by the manufacturer's design or did you add a second battery to the back of yout car for your uadio install. I never saw you mention one way or the other.
OK, will look at that now. Most BMWs have the battery in the right rear of the trunk, and have for a while now. Some Mercedes and Jaguar do this as well. I drive a 3 series.
In your case, you have to worry about "the circuit".. that's all. There are potentially two sources of power in your system, correct? The alternator, when the car is running... And the battery, when the car is not - or when the alternator is momentarily overtaxed. Well, if you are running thick power wire from your battery to your amps - all you are currently doing is ensuring that you have adequate enough power wire from the battery to the stereo equipment - which would be fine, if the battery were the only voltage source. After all.. you can trace that circuit, mentally: Current flowing from the + terminal, through your power wire, into your amp (which uses it to make music), out the ground wire, to the ground location, through the car's chassis, back to the battery's - terminal. (in reality, current flows the other direction, but that is a minor, unimportant technicality in the scope of this point). Now, instead - since the alternator is your primary source of current - and more importantly, one source that you don't want to choke off, making it inefficient for the alternator to do it's job - let's trace that circuit: Current flows out your alternator's + post, through some [at this point] mystery wire, aaaaallll the way back to your rear mounted battery... ...where the current then flows into your power wire, into your amp (which uses it to make music). Then, the current flows our your amp, through the ground wire, through the chassis, through the ground wire to the engine block, through the engine block itself, finally returning to the alternator via its chassis ground. Phew! That one was much longer. My question is - do you believe this "mystery wire" is large enough to support the current draw that you are going to be potentially pulling through it?
I hope it can simply for a test. I plan on getting a newer car sometime soon. I just want to make sure my stuff works and that I will know how to install it when the time comes. If i need to upgrade the wires on that vehicle (same model, newer year) i will. thanks for all the help everyone, its been great getting all of this help here, better than i would have gotten at other places.
Glad we were able to help. I gotta say that goe's last post was very good about laying out the whole circuit idea in layman's terms. James, I would suggest you really think about upgrading the alt to + battery wire since you are going to be running a pretty beefy amp. I also suggest this since you are getting all your wire for cheap or free. You could always use the wire again in your next car.
