/ Register
Viking Audio
Discussion in 'General Car Audio Discussions' started by electrolytic, Apr 18, 2007.
  1. electrolytic
    electrolytic Full Member
  2. electrolytic
  3. electrolytic
  4. electrolytic
  5. pedro quiroga
    your comitted to it now.lol.
  6. aznboi3644
    You know you didn't even have to cut up your door panels to even make some fiberglass pods. Could have just made some speaker rings and use some dowel rods to raise em up a lil and glass over that.
    I'll try to find some pics
  7. electrolytic
    I have a plan! lol The speakers sound amazing now, using the door as a box. This is the best front stage i have ever had lol, along with the factory tweeters up by the mirrors. It's actually worthy of being called a front stage.. So, i'm going to cut the door panel right in half along the curvy line below the handle and replace the whole bottom piece with fiberglass over top of the 6x9s sealing them in and also a small port. Yes?
    I have to cut the bass at 50hz and sometimes 80hz on my deck, depends on the music, they are still a little floppy on the low notes, so i figure sealing them in there will be more pressure on them and will perform tighter. Find those pics azn? Would still like to see some other designs.
  8. electrolytic
    Hey azn, i had to prove you wrong lol, You said i wouldn't get any bass out of these, only midbass. These infinity reference 6x9s are sweet. Check out the video, my camera sucks so it's dark and sounds a little distorted at times but that's my camera not the speakers. This is only with my deck and two 6x9s and a 100 watt amp.
    My first utube video wohoooooo.
    YouTube - Infinity reference 6x9's
  9. aznboi3644
    I don't think I ever said 6x9s would never make any bass...I normally state that like 6.5's or smaller won't get much bass from them lol...nice vid though
  10. electrolytic
  11. pedro quiroga
    man...forget those 6x9's get somthing like this..lol
  12. pedro quiroga
    3 10's in each door would sure give you that front stage.lol
  13. electrolytic
    ya, lot's of things i could do i guess, those look like 8's
  14. electrolytic
    Woooo, i just sold my Rockford Fosgate TRF-2212 SPL Competition Subwoofer !!!!!!!
    Soooo, i have $470.00 canadian to get another sub, Azn, was thinking elemental designs, they have a dealer here in Canada. Which one should i get!!
    TRF 2212
    Product Name TRF2212
    Nominal Diameter 12 in (305 mm)
    Magnet Weight 400 oz (11,340 g)
    Frequency Range 45-200 Hz
    Nominal Impedance 2 x 1.5 ohms
    DC Resistance (Re) 2 x 1.4 ohms
    Resonance Frequency (Fs) 45 Hz
    Total Q Factor (Qts) 0.21
    Electrical Q Factor (Qes) 0.23
    Mechanical Q Factor (Qms) 3.916
    Effective Cone Area (SD) 84 in^2 (0.054 m^2)
    Equivalent Air Volume (VAS) 0.98 ft^2 (27.8 L)
    Compliance (Cms) 6.85E-05 m/N
    Moving Mass (Mms) 6.46 oz (183 g)
    Voice Coil Diameter 4 in (102 mm)
    Voice Coil Winding Width 2.42 in (61.5 mm)
    Voice Coil Former Material 8 Mil Aluminum
    Voice Coil Inductance 4.32 mH
    Force Factor (BL) 26.33 Tm
    Linear Excursion (Xmax) 0.61 in (15.5 mm)
    Sensitivity (SPL) 92.6 dB
    Operating Power (PE) 2000 W RMS / 4000 W Peak
    Mounting Diameter 10.813 in (275 mm)
    Mounting Depth 8.125 in (206 mm)
  15. electrolytic
    oop, that didn't work
  16. aznboi3644
    how much power do you have to work with again??
    I plan on getting a 13Ov.3 just for the hell of it and building a transmission line for it
  17. electrolytic
    The canadian site is under construction sigh... I sent an email to Brent at Portimex asking about the 190v2 or the 13av2. I have 800 watts rms at 2 ohms
    1600 watts at 1 ohm, if i want to burp it? lol
  18. pedro quiroga
    i'm sure they were 10's maybe 12's
  19. pedro quiroga
    this thing was ridiculously loud.
    if your going to glass your front doors then maybe a 7in or 8in mid bass would work for you.
    if not those 6x9's seem to do the job too.
  20. electrolytic
    holy...lol ok they look big there. Ya i may do that, a ten in each door should do it.
