/ Register
Viking Audio
Discussion in 'General Car Audio Discussions' started by electrolytic, Apr 18, 2007.
  1. G3n3R@1
    G3n3R@1 Full Member
    it doesnt matter where anything is so long as the volume stays the same. just make sure your subs are facing back and like we discussed either do port back or port side.
  2. cccullen
    got it. It's going to be subs back and port back.
  3. electrolytic
    electrolytic Full Member
    Try and keep the ports on the same side as the subwoofer, otherwise i would have designed it different with longer ports. The idea is that if the ports are on the same side as the subs then the air inside the box can equalize with the air outside the box and with the air that the sub is pushing from the front. Lol sorry i have a hard time explaining sometimes on here.
  4. electrolytic
    ok, i sold my computer so i could buy an amp lol. So i might grab this tonight online if no one has anything bad to say about it. I can run it at 4 ohms and it will be perfect i think, also if i get another stroker in the future i can drop the amp to 1 ohm.
    POWER ACOUSTIK PS1-5500D
    Power series class D monoblock car-amplifier
    RMS Power Rating:
    4 Ohms: 1700 Watts x 1 Channel
    2 Ohms: 2500 Watts x 1 Channel
    1 Ohms: 3200 Watts x 1 Channel
    Max power output: 5500 watts x 1 channel
    Full regulated PWM MOSFET power supply
    Wired remote bass level control included
    LED power and protection indicators
    Tuned Bass EQ (0-18 dB bass boost at 45 Hz)
    Hi Speed Digital Circuitry
    Preamp RCA outputs
    4-Way Protection circuitry
    Platinum-plated RCA level inputs
    Platinum-plated screw terminals
    Variable low-pass filter (50-150 Hz)
    Subsonic Filter (15-40 Hz)
    Frequency response: 15-150 Hz
    Dimensions: 18"L x 11.4"W x 2.4"H
    1 Year Manufacturer Warranty
  5. pedro quiroga
    nice, cheap, high power. i say go for it.
    i knew a guy with the 3000d's (6 of them) and never had an issue with them.
  6. electrolytic
    sweet, ya i'm liking this amps specs, maybe i'll get a second one in the future for my second stroker if i get one and run them both at 4 ohms. I gotta move some money around but i will have it by the end of the month for sure, hopefully next week.
  7. electrolytic
    ......................... Brand New Power Acoustik Power Series Ps1-5500d 5,500 Watt Mono-block Car Audio Amplifier With Built In Crossovers And Advanced Features
    **3,200 Watts Rms Rated**..........
  8. electrolytic
  9. electrolytic
  10. cccullen
    Thanks electro, I was planning to keep the subs and port on the same side. What about internal bracing though, do i need any?
  11. electrolytic
  12. electrolytic
    I don't know lol, i guess it depends how good you can build it. Use wood glue and glue each piece, drywall screws, 1/64 drill bit and put screws every 4 inches or so and i don't think you will need any. I didn't brace mine, it turned out pretty solid. Countersink the screw holes too if you can with a drill bit a bit bigger than the screw heads.
  13. electrolytic
    It's officially mine, all mine....Can't wait
  14. pedro quiroga
    good luck with this one lol.:cool:
  15. electrolytic
    Thanks lol, i think this setup will be ok finally, at 4 ohms it should run cooler and be easier on everything. I noticed my car is running a little rough lately but a weird thing is happening now, when i'm driving a good speed then have to slow down real fast the engine kind of dies out for a second and my 200 watt amp cuts off for a second. Grrr, there is some heavy power surges going on with my car i think and maybe has been like that for a long time but not as bad. It has to be a big surge or lack of power for a second or two because i'm only running a 200 watt amp and it has it's own battery in the back. Probably not good for an amplifier in this situation.............
  16. cccullen
    thanks electro. I was going to put a screw every two inches like my last box. Damn box must have taken like 60 to 70 screws.lol My last box i did glue everything and then tacked it together then put screws. the only thing i didn't do was pre drill. I'm going to do it this time though.
    congrats on your new amp. Maybe you should have your alternator checked before you install the amp though. Make sure your electrical is all in order. I know you don't want to fry another amp.lol
  17. cccullen
    electro, last question. the PVC has to 4" diameter PVC or 4.25"? I'm a little confused.
    (e), specifies 4.25" and (g) specifies 4". wouldn't the height and width of the PVC be the same?
  18. G3n3R@1
    G3n3R@1 Full Member
    1/4" for the thickness.
  19. cccullen
    ah ok. Thanks for the clarification G3.
