It would fry lol... Orion HCCA2100 2 x 100W @ 4 ohms 2 x 200W @ 2 ohms 2 x 400W @ 1 ohm 2 x 800W @ ½ ohm (competition only) 1 x 400W @ 4 ohms bridge 1 x 800W @ 2 ohms bridge 1 x 1600W @ 1 ohm bridge (competition only) THD: 0.03% S/N Ratio: 110dB Freq. Response: 6Hz ∼ 30kHz (±0.5dB) Fuse: External 120A Dimensions: 23" x 8" x 3.125" (59cm x 20.3cm x 7.9cm
Hifonics is NOT better than the Orion but the Hifonics amp can run at 1ohm all day long. That's what electro needs. His orion was a beast but it can only run at 1ohm for short periods for competition purposes only. Where do you plan to ground the amp? Remember you gotta keep that ground wire very short.
This Hifonics 2200D is an orion Killer!!!!! Makes the orion look like a pyramid haha. Hopefully...Way more power and class D design and 1 ohm stable. The Cerwin Vega is going to be jumping!! For daily use the orion is only good at 2 ohms which is about 1000 watts.
I'm sure you'll be happy with that Hifonics amp. So, when you getting it??? I'm still waiting for all my sh!t. Damn, it's taking too loooooooooong...
Ya, i gotta hustle up some more cash. I have some 1/0 guage left will use it up for sure where i can before the amp arrives!!
big 3, still need more 1/0 gauge but at least the front is mostly done, need wire loom too and heatshrink would be nice lol.
not yet, it's on it's way though, hopefully by friday. I hope it doesn't pull more than 100 amps, i'll be popping fuses. It has 2 gauge power connectors.
dude i forget,but what did you get again? also if it's you....then 100 amp fuse wont do at all.lol. i have a 150 front and back as per ED's recomendation.
Hifonics BX2200D - Hifonics Brutus 1 Ch. 2200 Watt Amplifier • 2200 Watts x 1 Chan. @ 1 Ohm RMS • Class D Mono Amplifier • Super D-Class "Generation" Chip Set • New Hifonics Twentieth Anniversary Heatsink Design • Illuminated Hifonics Badge • Illuminated Maxxsonics M • Bass Remote with Blue LED Power On & Diagnostic Indicator Included • Ultra-Fi MOSFETS • SPC - Simpatico Coil Design • HSMD - Hifonics Surface Mount Design • Fully Adjustable Accu-Cross Crossovers • PWM MOSFET Power Supply • Soft Start • Line Output • XLR Mini DIN Sockets for Balanced Line Input • Variable Bass EQ: 0 - 18 dB • Sub-Sonic Filter: 15 - 35 Hz • Variable Input Level: 200mV - 9V • 2 Gauge Power Connectors • Additional MOSFET Output Devices • Power From The Gods Included • Dimensions: 20.5" L x 2.63" W x 10.39" H • Amplifier Specifications: • Amplifier Class N/A • Number of Channels 1 - Mono • RMS Power (4 ohms) 550 watts x 1 channel • RMS Power (2 ohms) 1100 watts x 1 channel • RMS Power (1 ohm) 2200 watts x 1 channel • Bridged RMS Power Not Bridgeable • Peak Power Output 4400 watts approx. • Minimum Impedance Unbridged 1 ohm • Minimum Impedance Bridged Not Bridgeable ohms • THD at Rated RMS Power 0.1% • Speaker Level Inputs No • Preamp Outputs Yes - 1 pair • Built-in Crossover LP ( 35 - 250 Hz), Subsonic(10 - 20 Hz ) • High-Pass Crossover Frequency N/A • Low-Pass Crossover Frequency N/A • Subsonic Filter N/A • Signal-to-Noise Ratio 95 dB • Channel Separation N/A • Bass Boost 0 - 18 dB (30 - 60 Hz) • Bass/Gain Remote N/A • Fan Cooled Yes • Fuse Rating N/A
