Viking Audio
Discussion in 'General Car Audio Discussions' started by electrolytic, Apr 18, 2007.
  1. pedro quiroga
    then if it has a ski hole put it behind the seat.
  2. electrolytic
    electrolytic Full Member
  3. electrolytic
    I put the box back in the trunk but facing forward this time, i think this is the best design for my car, the trunk does help create a more smooth deeper bass, just not as hard hitting as when i had it in my back seat. I guess i need more power now and the stroker. I'll get the dual 2 ohm sub and run my amp at 1 ohm and be real gentle with it!! Haha ya right. That should put me around 2000 watts rms.
  4. electrolytic
  5. electrolytic
  6. electrolytic
  7. electrolytic
    oh ya, my car's ok without the pac 200 relay and that voltage readout on the distribution block has been on for days and no problems. I will get a small relay for that though, not a big deal.
  8. electrolytic
    It's mine babyyyyyyy!!!!!!! wohoooooo, not the pro but i figured now or never lol
    Should get it soon, it's paid for. I have to post the info from the ad, it's funny.
    CERWIN VEGA STROKER 122 12" 4000 WATT CAR SUBWOOFER SUB
    The Cerwin Vega Stroker Stroker-122 is one of the most popular subs for competition level bass. This sub has an incredible 4,000 watts peak output and 2,000 watts RMS. This sub goes louder than you can imagine! It will make your car have louder subs than a night-club. These subs were also built to have great sound quality. They have a revolutionary dual-spider design making these among the most advanced subwoofers available on the market. These subs have high excursion, meaning the subs can breathe and has a lot of room to bump up and down to hit bass notes that other subs can't hit. It can hit an incredible frequency range, even while being played at high volumes.
    These subs are also extremely efficient due to an aluminum basket and an aluminum heat sink. This sub is also the strongest in its class, and will last a life time. This sub is designed to get rid of heat so it always plays smoothly, and never overheats! Being that this sub is designed for competitions, it has a replaceable cone, so if you are pumping to much power to it at a competition and blow the sub, you can replace the cone quickly and get right back to your competition and still win!
    This sub is so big, it is scary to look at it (specially if you are competing against car with these). It is a 47.3 pound beast! We have a very limited quantity available at this price, so buy it now!
    My name is Chris, and I am a professional installer, and a car audio expert, and if I were able to choose any sub in our own ebay store, I would go with a Stroker! These subs are the best!
    * 12" Dual 2 ohm Voice Coil Subwoofer
    * 4000 watts Peak
    * 2000 watts RMS rated and tested
    * 47.3 Pounds!
    * Sensitivity: 84 dB 1w/1m
    * Ellipsoid Surrounds eliminates distortion and ensures great sound quality
    * Integrated Voice Coil and Heat Sink and Ring
    * High Temperature Dual Coil Design
    * Dual Gap Motor Design
    * Surround Clamping Ring
    * replaceable cone
    * Spider Clamping Ring
    * Integrated Speaker Terminals
    * Axial Edge Surround System
    * Field Replaceable Cone
    * Mounting Diameter: 13.125" inches
    * Mounting Depth: 8" inches
    * Diameter: 12"
    * Frequency Response: 40~200 Hz
    * Voice Coil Diameter: 3.0"
  9. electrolytic
  10. aznboi3644
    nice...2000 watt power handling. Electro...I'm sure this sub will last a while. I bet you won't blow it any time soon lol
  11. pedro quiroga
    im sure he will try.lol
  12. electrolytic
    lol, i shouldn't have to worry about that now, as long as my amp doesn't melt it should be sweet!!
  13. electrolytic
    stroker 12" ported 40 hz
  14. electrolytic
  15. electrolytic
  16. aznboi3644
    from the cone displacement graph the enclosure looks a little on the large size
  17. electrolytic
    ya, was wondering about that but the only way i can get the excursion over that is to tune this thing to like 34hz, this is more the size of box i want i just measured my trunk again to double check.
  18. electrolytic
  19. electrolytic
  20. electrolytic
