Maybe this? Cerwin Vega Stroker 154 15" 4000W Dual 4-ohm Subwoofer Sensitivity: 86.3 dB RMS Power Range : 2000 Watts Peak Power Handling: 4000 Watts Impedance: Dual 4 Ohm Low Frequency response: 20 Hz High Frequency Response: 300 Hz Diameter: 15 Inch Features 15" Dual 4 ohm Voice Coil Subwoofer Ellipsoid Surround Integrated Voice Coil Heat Sinking and Modulation Ring Extremely High-Temp Dual Coil Design Dual Gap Motor Design Surround Clamping Ring Spider Clamping Ring with Integrated Speaker Terminals Axial Edge Surround System Field Replaceable Cone Assembly Mounting Diameter: 16.25" (412.8 mm) Mounting Depth: 9" (228.6 mm) Weight: 34 lbs. (15.42 kg)
damn wtf lets try it again haha Elemental Designs 12Q 12" Subwoofer - (eBay item 190150393444 end time Sep-13-07 17:19:05 PDT)
Ok, i think i'm going to settle with a 10" Cerwin Vega Stroker, i found a used one with a box built to specs for $250.00 locally. Unless anyone has anything bad to say about them. It's rated @ 2000 watts rms and is a dual 2 0hm. The seller is willing to demo it for me with 1700 watts rms so it must be still good.
Ya i wish, but i would need about 10 hccas to power it. Elemental designs doesn't have a subwoofer that is 2000 watts rms as far as i know. What about this Cerwin Vega Stroker? Anyone have or tried it or heard it or know anything about them? It is 2000 watts rms 3000 watts peak. I should get the Orion H2 and be done with it but i don't have $900.00 to shell out.
Pioneer Premier TS-W5102SPL - 12" Dual 2 ohms Premier® SPL Subwoofer • 6000 watts Peak, 2500 watts RMS • Rubber radial surround • Interlaced Carbon Fiber Reinforced IMPP Cone • Cast Aluminum Basket - , Component Subwoofers, 12" Component Subwoofers -
12Q ? what is that? i don't see or know which sub it is can you put a link? I told the dealer of ed i was going to set my sub on fire with lighter fluid LOL, poor bastard
Wow, what a difference in prices on this, it's on sale save $450 LOL http://www.cardomain.com/item/ORI27311?utm_source=shopping.com&utm_medium=product_feed Orion H2 15.2 * Heat-hardened, ultra-rigid aluminum cone * Nitrile-butyl rubber (NBR) surround with large roll profile * Massive proprietary die-cast aluminum basket * Patent-pending dual gap geometry motor assembly * Dual flat spiders * Raised vented spider tower * Die-cast mounting clamps * Rubber sealing wrap gasket * Double stacked internal & external magnets * Vented pole piece * 3" two-layer copper voice coil on aluminum former * Proprietary AngleLock wire terminals * Optimized performance in high-output sealed or ported enclosures * Mounting depth: 9.75" Subwoofer Specifications * Size: 15 inch * Rec. Sealed Box Dims: 1.50 - 2.50 cu. ft. * Rec. Ported Box Dims: 2.25 - 3.00 cu. ft. * Free Air Usage: not recommended * Sensitivity: 88.9 dB * Frequency Response: n/a * Recommended RMS Power: 2,000W * Peak Power Handling: 2,500W
This looks very sweet too, damn i guess i'm gonna have to start hustling up some doe, i think this one is more for spl though, i want sq * 12" 2 ohm DVC Premier SPL Subwoofer * Power Handling: o Peak: 6000 watts o RMS: 2500 watts * Interlaced Carbon Fiber Reinforced IMPP Cone * Rubber radial surround * Ultra-Strong Dust Cap With Foamed Acrylic Polymer * Aero-Dynamic Magnetic Gap * Ceramic-Coated Voice Coil Wire * Pure Titanium 3" Dual Voice Coil * 320 oz. Triple-Stack Magnet Assembly * Cast Aluminum Basket * Frequency response: 18-2,000 Hz * Sensitivity: 88 dB * 1-year Sonic Electronix warranty Subwoofer Specifications: * Subwoofer Size 12" * Dual Voice Coil Yes * Impedance Dual 2 ohms * Peak Power Handling 6000 watts * RMS Power Handling 2500 watts * Woofer Surround Wide-Roll 3-Layer Fiber Radial Surround * Woofer Composition Interlaced Carbon Fiber Reinforced IMPP Cone * Sealed Box Volume N/A * Ported Box Volume 1.5 cubic feet * Sensitivity 88 dB * Frequency Response 18 - 2000 Hz * Xmax (millimeters) 11.5 mm * Top Mount Depth 10-1/2" * Cutout Diameter 10-7/8" * Warranty 1-year Sonic Electronix
those pioneer premiers set the dB world record. Elemental Designs News Blog scroll down to September 6th just before half way down the page and its in the first picture with the 12" diameter magnet.
Sweet thanks for that info azn, yes i remember when i ran it through bassbox before it wasn't responding well, i though it might be me lol
yes, i did get the link in the email sent to me and i saw it on ebay just figured it was 1000 watts or so lol. You know what though, one of the administrators here i think wanted it more because they kept deleting your link to it. Bastards!! That's a little dirty, i wouldn't have bid anyways, that sub would need way too much power to even move it. Shame Shame Admins.....Double shame, now i know your dogs name haha
i've also read that the basket isn't strong enough to support the magnet, that sub was just a freak of nature prototype. Only solution i've found is to build supports inside of the box to hold up the magnet.
