Viking Audio
Discussion in 'General Car Audio Discussions' started by electrolytic, Apr 18, 2007.
  1. aznboi3644
    haha...we'll see
    :eek: an online challange.
    hmmm.....send in your best sub vid and we will judge you.:D
    do like a water bottle thing.or... hell i dont know.whats another sub thing to do?
  3. electrolytic
    electrolytic Full Member
    haha, There must a place to get a cheap db meter.. Ok but wait i need dual 4 ohm subs not 2 ohm yes?
  4. electrolytic
    Orion HCCA 2100
    2 x 100W @ 4 ohms
    2 x 200W @ 2 ohms
    2 x 400W @ 1 ohm
    2 x 800W @ ½ ohm (competition only)
    1 x 400W @ 4 ohms bridge
    1 x 800W @ 2 ohms bridge
    1 x 1600W @ 1 ohm bridge (competition only)
    THD: 0.03%
    S/N Ratio: 110dB
    Freq. Response: 6Hz ~ 30kHz (±0.5d
    Fuse: External 120A
    Dimensions: 23" x 8" x 3.125" (59cm x 20.3cm x 7.9cm)
    Elemental Designs NINe.1
    1 x 450W @ 4 ohms
    1 x 900W @ 2 ohms
    1 x 1200W @ 1 ohm
    S/N Ratio: -95dBA
    Efficiency: 64%
    Damping Factor: 300
    Max. Current Draw: 130A
    Fuse: 4 x 30A
    Dimensions: 14.7" x 9.85" x 2.25" (37.3cm x 25cm x 5.7cm)
    __________________
  5. mrmizcue
    mrmizcue Full Member
    yes dual 4ohm will give you your 1ohm load
  6. electrolytic
    I don't know why this still confuses me, i can't seem to get a grip on this lol. So wired like that @ 1 ohm bridged would mean that each channel is running at 1/2 ohm yes? So i'm actually running at 1/2 ohm per channel, is this what i want Lol i hate being confused it's irritating....
    Even though each channel is running 1/2 ohm that still means i'm running at 1 ohm for the specifications?/////
    Orion HCCA 2100
    2 x 100W @ 4 ohms
    2 x 200W @ 2 ohms
    2 x 400W @ 1 ohm
    THD: 0.03%
    S/N Ratio: 110dB
    Fuse: External 120A
  7. pedro quiroga
    yes. each channel see's half the load.
    800x2 @ 1/2 ohm
    1600x1@ 1 ohm
    its the same.
  8. pedro quiroga
    dont forget.its closer to 1000-1200x2.those amps are VERY!!! underated.
  9. G3n3R@1
    G3n3R@1 Full Member
    that would unleash the beast inside of those 19Ov.2s, damn that'll be loud.
  10. electrolytic
    haha, yes!! I can't wait till it's finished, this time it will be done right.
  11. electrolytic
    Guess what!! I figured i'd try the sub one last time on my home system to make sure and both coils are working fine! I can't find my multimeter right now though. Must have been my crappy install lol rattling wow, or the sub was twisted or my amp is crapping out, or maybe my rcas lol. What the hell, and what did i smell burning before lol. There is no distorted noise now, the little bit of distortion in the video is from my crappy camera.
    YouTube - Toronto Elemental Designs Orion Car Audio Systems
  12. pedro quiroga
    hmmmm.have you had the amp tested?
  13. electrolytic
    ummm, ya by me haha, how can i test it, you mean with an oscilliscope? I measured the coils on the sub, found my meter, they are both good i think, they are jumping around 3.9-4.1 ohms each.
  14. pedro quiroga
    i would check each ch with another speaker/s to see if both are putting out the same power/voltage.
    i wouldnt know how to use a O scope anyways.lol
    process of elimination?
  15. electrolytic
    sigh..............It's tough to create the most ultimate car system in the World...A system that co-exists with it's particular environment and creates a multiplexing effect of algorythms of raw data sent spiraling into a vortex of the resonance and speed of sound. At least enough to pawn Azn and Pedro HAHA...
    ED RULES................................................................
  16. pedro quiroga
    ummm my system still works.....who said that!
    sorry man just messing with ya
  17. mrmizcue
    i thought i remembered seeing somewhere that you can test the out put of a amp with a multi-meter...i will look
  18. aznboi3644
    haha...just wait.
    By the way my friend is gonna sell me his Type R 15 for 100 bucks...its max power its seen is from my Nine.1...1200 watts for a few minutes...took it like it was nothing
  19. pedro quiroga
    i just finished rewireing my amps for more rms power and..guess what electro.
    my sub is hittin harder with less power.all i did was turn it faceing up and the port now fires into the drivers side.
    so 18 or not i'm coming for you!!! lol.
    naa really i had to turn the bass down from 0 to -10 and thats still a little bass heavy,but i dont mind.lol.
    i wonder if i put the M50 back onit@350 what it would do on the meter?oh and my voltage is down some.
    245 per door,20 per dash,40 per rear fill, 220to the sub.
  20. electrolytic
    make that 18"s with an ssss LOL it's getting close to Whoopin Time!
    YouTube - bass
