Upgrading to a powerful system (1500+ watts)
Discussion in 'General Car Audio Discussions' started by eazy, Jul 9, 2007.
  1. jmenace_thakidd
    jmenace_thakidd Full Member
    get the Q then they are the SQ subs the SSDs are good subs but the Qs can handle more then the 1000 rated just but i wouldnt put more then 1200 to them cant wait to see what yu decided and see the install
  2. aznboi3644
    If you are going Fi i'd say two BLs...they'll take that 1500D easily.
    The 1500D's aren't warrantied for anything under 1 ohm so if you blow it you are screwed
  3. eazy
    eazy Full Member
    Well I'm warrantied at 1 ohm right? I wouldn't run it any lower than that. The bottom line is, I'm going to see 1500 watts from the SAZ-1500D, the SSD's can take at least 800, and the Q's and BL's at least 1000. The SSD's are $189 each and the Q's and BL's are $259 each. I gotta decide.
  4. aznboi3644
    Yeah they are still warrantied at 1 ohm.
    I love the style of those amps...simple and look like just pure power.
    Yeah I fuking hate deciding...never can
  5. jmenace_thakidd
    damn hard desicion if you put 2 SSDs on the 1 1500d theywould take them great because i have seen 1 Q or BL take that 1500d with no problems
  6. pedro quiroga
    i forgot where i saw it, but i saw somewhere that amp can do over 2k's with enough voltage.
  7. eazy
    eazy Full Member
    Alright, what do you think, should I do 2 12's ported or 2 15's sealed?
  8. electrolytic
    electrolytic Full Member
    Hey eazy, you still going..lol I don't know the subs you are looking at but one nice 15" would allow you to build a bigger box.
  9. pedro quiroga
    if you want brain numbing bass go for the 15's.
  10. eazy
    eazy Full Member
    You think the 15's sealed would be louder than the 12's ported?
  11. pedro quiroga
    why not ported 15's?
  12. eazy
    eazy Full Member
    I can't run them ported with the spare tire unless I come up with something insane.
  13. danracer
    danracer Full Member
    why dont u use a wedge box???
  14. eazy
    eazy Full Member
    ...what do you mean?
    I need 8 cubes of airspace after port, sub, and brace displacement for the 2 15's ported.
  15. danracer
    which 15's are u planning on using?
  16. danracer
    ohh and what are the measurements of ur trunk
  17. eazy
    eazy Full Member
    what my trunk looks like empty...
    Max width= 39"
    Max depth= 24"
    Max height under tire= 14"
    Max height in front of tire= I believe 21"
    Tire hangs out over edge= I believe 8"
    I've built ported boxes by the way. I've just been having trouble getting 8 cubes tuned to 33 Hz with enough port area. I figured the whole box should be double thick 3/4" MDF.
  18. eazy
    eazy Full Member
    Oh and probably the Fi SSD15's or Fi Q15's getting at least 750 real watts each from the Sundown Audio SAZ-1500D.
  19. danracer
    hmm the most i can get out of those dimensions is 5cuf
  20. danracer
    cant u move the tire anywhere else?
