The Big 3....
Discussion in 'Automotive Electrical' started by TheViking, Nov 13, 2006.
  1. electrolytic
    electrolytic Full Member
    Pyle PLCPBT25 25 FARAD/22AH Car Battery Style Capacitor
    # Compact Design for Optimal Storage Possibilities
    # Works with all Car 12V Installations
    # Extremely Fast Recharge Rate
    # Low E.S.R.
    # Auto On/Off Switch Control
    # Electronic Polarity Protection
    # Wide Temperature Endurance: -40¦ ~ 95¦
    # 25 FARAD/22AH
  2. electrolytic
    Pyle Cap or pile of crap LOL
  3. aznboi3644
    pyle of crap still...please don't waste your money on this.
    Upgrade all of your wiring to 0 gauge if you can first.
    What kind of battery do you have back there anyways??
  4. electrolytic
    It's a Honda lol, but pretty big, not sure on the rating, i think it's at least 750
  5. electrolytic
    an older pic but that's it.
  6. aznboi3644
    is it a sealed battery?
    No wonder your amp pulls so much current...its twice the size of the damn battery
  7. electrolytic
    lol, i think it's sealed. I will check tommorow and see exactly what it is.
  8. DMP
    DMP Full Member
    I recommend a Kinetik battery. Better than Optima, IMHO.
  9. electrolytic
    ok, thanks, can i get away with the cheapest one? Would it still be a LOT better than mine, this kinetik is 850 amp, about the same as what i have now. My orion can pull about 120 amps.
    Kinetik HC600 Power Cell "The Cap Killer"
    All Kinetik HC Power Cells Feature:
    AGM Technology
    Sealed Non-Spillable Design
    Mount In Any Position
    Ultra Low ESR
    More Plates For Stronger Energy Density
    Higher Voltage Under Load
    Tightly Packed Cells
    Superior Heat & Vibration Resistance
    Weight: 14 lbs.
    Ah: 20
    Amps: 850
    Dimensions: 7" x 3" x 6.5"
    Suggested Retail: $199.00
    Kinetik - High Current Car Audio Power Cells
  10. electrolytic
    Mine is a toyota lol not honda.
  11. electrolytic
  12. aznboi3644
    retails for 400 bucks...you can get a Kinetik 2400 for under 300 bucks shipped
  13. electrolytic
    ok, cool, i have a 1200 cca durolast gold in the front so i should be good then.
  14. DMP
    DMP Full Member
    You can get Kinetik batteries alot cheaper on Ebay than directly on their website. Now let me back up my comment about Optimas. Alot of people "swear" by them, and then theres others that have problems with them. I know somebody who had problems with their Optima. I belong to another forum, and a member there said they went to a car audio show...the Optima was on the charger the whole time, while Kinetik lasted for days. I dont really know if they meant the companies were there or what. BTW, be careful what batteries you buy....some are just re-badged and sold for more.
  15. electrolytic
    Thanks! That's good to know..One kinetik coming up lol, time to hustle.
    Kinetik-HC2400-Power-Cell
    Kinetik HC2400 Power Cell
    MOST POWERFUL audio cell anywhere, PERIOD! Used in the loudest vehicles in the world and boasting over 180dB when used in competition. This bad boy has more current than power cells twice its size. If you want the BEST, this is it. Providing thousands of amps at near dead short, this power cell performs best when abused.
    Specifications
    Weight: 69 lbs.
    Ah: 128
    Amps: 2600
    Dimensions: 13" x 6.7" x 8.5"
    Suggested Retail: $449.00
  16. electrolytic
    ugh, i think it's an inch too big for my rack. Nothing is easy...for me anyways
  17. manutdfan7
    manutdfan7 Full Member
    hey viking your really bloody smart
  18. cccullen
    Bringing this thread back to life because i found out something. I may have misread or something but i wanted to mention it.
    I have done the big three (alt to batt pos, ground neg terminal to engine, and ground neg terminal to chasis). Still got dimming though until this day!
    Now, i read somewhere on a ford forum that the most important ground is the alternator to chasis ground!
    NOTE: Realize that the "absolute ground" of the electrical system is not the battery negative terminal or the vehicle chassis, but is the case of the alternator itself. This is why perhaps the most important cable among the Big 3 is the engine ground strap, as this is what connects the alternator ground to the vehicle's chassis. Be certain the resistance between the alternator case (the engine block assuming the alternator is properly bolted to the engine) and the battery negative is minimized.
    I just wanted to point that out I'll be taking care of this tonight so I'll give y'all feedback if it solved my problem.
  19. electrolytic
    sup dude? lol hope everyone is doing good. I have been a little busy, my car is doing awesome, havent gotten around to installing my sytem yet, might wait until next year, too much work lol. I had to get the engine rebuilt and a ton of parts but she's rocking now. Will post some pics and vids i took along the way for you guys! Haven't forgot about you's. CC ya they are all important, it is one big loop. The engine is usually mounted on rubber mounts so it doesn,t actually get a good enough ground so they put the strap from engine to chasssis. I notice a lot of cars where that strap is broken and the car will still run fine but when you go to hook up a heavy system there is problems.:)
  20. cccullen
    Damn electro, where you been hiding????
    my engine took too long to cool down so i wasn't able to work on it tonight. So should i just make a new ground from the alternator bracket to the chasis?
