Switching it up
Discussion in 'Car Subwoofers' started by tommy2tone, Nov 24, 2010.
  1. Ranger SVO
    I always start around 100 or a little lower. I can fine tune it after all other adjustments have been done.
    Bass on radio at -1 to 0, volume at about 3/4. Gain should be all the way down. Set bass boost to about half. Turn up the gain slowly. If you think your close, listen to it for a few minutes before adjusting again.
    If you decide you want to try more bass boost, turn the gain all the way down, increase the boost slightly, then adjust gain.
    I've set boosts (depending on car and sound system) between 1/2 and 3/4 with very good luck.
    Just make sure you remember where your controls are set now, just in case you hate my method.
  2. tommy2tone
    tommy2tone Full Member
    OK,so here's the setting from where I started:gain 1/2,bass boost 0,loudness off,bass on h/u 2,lpf 62hz.
    This is how it is now:gain 1/4,bass boost 1/2,loudness 0,bass on h/u 0,lpf 85hz.
    It is hitting harder,but I was turning the gain up slowly and it started cutting out.It didn't go into protect either,so I turned it back down and started over.
    I've got it set pretty good now,but my comps are now lacking some mids.I have a bass boost on my component amp(http://www.mobileonesales.com/ProductDetails.asp?ProductCode=EA3422 ),should I try and adjust it?
    I have the amp bridged to these comps:http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=7929,so they are seeing about 100rms each side.
    With the bass at 0,I can turn the h/u way up past 3/4 before they distort or clip.Like 46 out of 50,I usually max it at 38.
    I've turned the hpf off and my amp is on through so no filters to the fronts at all.
    When I turn the sub off,it really sounds terrible,I know that I'm not looking for lows out of the fronts but it sounds bad.
    I usually set the fronts to sound good whether I have a sub or not,but there's no way possible to make these sound the way I want.
    Maybe I'm just asking too much from these comps,or sound deadener is in my forecast.
  3. TheViking
    I would suggest keeping the high pass on to your front speakers. If it is adjustable, turn it up to a higher frequency, say about 200 Hz.
  4. tommy2tone
    So a gap between the fronts and the sub is ok?It sound different,not the way it should.
  5. tommy2tone
  6. TheViking
    typically, when setting the hi and low pass x-over points, you want a little bit of a gap. this is due to the rate at which the frequencies roll off, or what is called the slope of the x-ver expressed in dB/octave. THis usually allows for better bass and midbass performance. Now, with that said, this does not ALWAYS hold true. speaker placement, and personal sound preferences will ultimately dictate the final settings.
  7. tommy2tone
    I understand what your getting at.I'm trying to get my fronts to sound good with or without a sub,if it's even possible.I'm not looking for killer bass out of the fronts though.
  8. TheViking
    Having the subs and the highs all play sub bass is a bit tricky...we get into whats called "phasing issues" Try this.....invert polarity to the subs and see if overall bass performance is better
  9. Ranger SVO
    And I suggest just the opposite, no high pass, unless your running a 3-1/2 of 4-inch speaker. Any other speaker should be able to handle everything. When ever I've used a high pass filter, transient response suffered. So I decided that if I need more bass, let the subwoofer do it.
    If you do need a bass blocker then keep it low, no more than 40 to 80Hz. But seriously, I've never used a high pass filter on my front speakers, even my 6-1/2-inch center channel in my truck is run full range and its being driven at 180-watts RMS and its rated at 60 watts RMS. The amp gain is nearly 2/3 of the way up.
    If it doesnt sound right with those adjustments, then the box and the speaker are the problem, they are not working together.
    Can you get me a link to your speaker specs.
    I'd like to do a little more research
  10. Ranger SVO
    TheViking is right about the fact that a little gap is OK. The sound will "sum" flat if the gap is set right. I've never had good luck with summing flat in a car.
    Also, what I found is that if I run the front speakers full range, then even the bass sounds like its coming from the front speakers (transient response). The more high pass I use the more the bass moves away from the front speakers.
    That been my experience with high pass in a car
  11. tommy2tone
    I've given links to both my subs and my comps in earlier posts of this thread,you might have been posting when I did.The low end is better and not an issue anymore.Thanks for all of the help.I'm now just trying to get it to blend better.
  12. tommy2tone
    Update:I just got a alpine type r 15 dual 2 for 100 bucks new sealed in the box.One of my friends neighbor needed cash really bad.I already installed it,but have not had time to play with it.I'm sure when I get my new car I'll need to build a new box,but for now it's in my old one.
