Subwoofer Punch
Discussion in 'Car Subwoofers' started by sandt38, Aug 22, 2003.
  1. sandt38
    sandt38 Full Member
    Yep :lol:
    You mom and I are sitting here reading this trying to irritate you :kiss:
  2. Krelkor
    Krelkor Full Member
    liar
    shes downstairs cookin me muffins before church
  3. The_spacemonkey
    The_spacemonkey Full Member
    wow.... this is a long(but very interesting thread). I havent yet read the whole thing, so dont beat me up if I say something that was already said. Seth, the BL curve point is an interesting one, But I believe it dosent hold water. With your theory, the more BL you have, the "punchier" the woofer will be since the point that supposedly has the most "punch" is the point with the most BL..... at least thats what it looks like your saying.
    Or if you are saying that subs with more parabolic curves are more" punchy" due to the lack of BL dropoff in the lower excursion-upper frequencies..... this also dosent make any sense. If you took a sub with a ruler flat BL then, it would be EXACTLY the same amount of punchy, because you still have limited excursion at higher frequencies, and you still dont have any real illinearity to speak of at that small of excursion. Actually, with that arguement, ALL drivers would be "punchy" throughout their entire pass band if you just turned down the volume(read:limit the excursion). Now I dont know about you, but I havent heard many subs that I would reguard as "punchy" at low volumes, and not "punchy" at higher volumes. Sure Ive heard many subs that just get plain sloppy at higher volumes due to extreme BL rolloff, but the sound that I relate to "punch" seems to be independant of excursion.
    just my $0.02
  4. systempimp_1500
    systempimp_1500 Full Member
    So, Seth, you're saying that a sub that can effectively produce upper midbass
    will have better transient response?
    Sounds reasonable to me.
    The way I see it, the voice coil will always hold a natural amount of Le, being there
    a signal or not. So.....eh.....it sorta goes against the Le determines transient
    response issue (not saying it doesn't, because it certaintly does aid in it).
    The way it's been presented in my head in the past is that frequency response
    IS transient response.......
    Goes hand in hand with what you said.....
    Think about it........
    Jeff
  5. sandt38
    sandt38 Full Member
    No, not really Jeff, the TR and upper midbass I mean. I know punchy subs seem that way, but I don't really consider that as the sub displaying better transients, after all, that is not a sub frequency ;) . Remember, the Kodas do killer with transients but they are not really a punchy midbass ;) .
    Bobby, i feel you. At low levels we need to consider FS as the basic factor... But a punchy woofer displays less "punch" at low levels (as discussed with Luv regaurding power I think), albeit a similar sonic character...
    Can we get more input?
  6. sandt38
    sandt38 Full Member
    **disclaimer**
    This is all theorectical. I am just trying to figure out the superwoofers really. They exhibit a certain charachter that is very unique. The only thing I can attribute the differances to are the BL curves. What I am finding is, as a general rule, the punchier superwoofers seem to have a more peaky Bl curve, and I am able to find that many punchy woofers are also SGLC woofers, which generally have a parabolic curve. Seem underhung drivers tend to be more laid back, and typically, we find underhung to maintain a flatter BL. With the superwoofer we are seeing fairly low Fs ratings, and I find the old FS rule seeming to fall out the window.
    I have yet to play with a B10, so I cannot say, but it may just throw my observations out the window. Steven said the 10W7 was as punchy as his B10... Well then... The B10 has a low Fs and flat BL, so that would throw a wrench in the works of my theory ;). But he said it was in a showroom. So I am interested in what the in car presents... Maybe Dan could drop me a B10 to play with :D . We can use it to convert Cort, the punchy woofer guy who doesn't know what he wants to do right now ;) .
    As I mentioned, "the general rule" though seems to have an exception and it is the W7. My conclusions are it's suspension may be the reason. While I know it is said that KMS and BL maintain no bearing on one another, I wonder. As you add suspension resistance, woln't the motor begin to show signs of weakening? For example, as the suspension travels X amount, it starts to become more resistive to the forward (or aft for you guys that are going to try to jump on this :lol: ) movement. My thought is yes, and Chris (Geo) and I have discussed this before, agreeing with this presumption. The 10W7 is punchy, yet it has a fairly blat BL. The ID has a more traditional parabolic curve, so it falls in line with my opinions as it is the punchiest of the bunch...
  7. BlkX
    BlkX Full Member
    If you ever come across a b10, i'll donate my 10w7 for a/b testing if you want.... I'd be interested to hear em both in the same car in optimum sealed enclosures.
  8. Steven Kephart
    Steven Kephart Full Member
    Actually I think what makes a superwoofer is it's incredibly large linear thow within an SQL driver. The flat BL curves are only on a couple superwoofers.
    Yeah, all I had available for the W7 was in the showroom. So since I knew I couldn't compare frequency response, I mainly listened for boominess and added distortion. In that respect it sounded identical to the Brahma.
    From what I understand, the BL and Kms effect different things, and therefore bring forth different distortions. It just so happens that the BL distortion is a much greater product of the total distortion than the Kms distortion. It seems that Kms nonlinearities effect the frequency response more (frequency response of sub changing with excursion), while the BL nonlinearities effect more the power input (BL compression). I'm not sure why that would be more audible than the Kms.
    Let's look at it this way. Kms nonlinearities effect the Qtc of the system (among other things). Let's take a look at this white paper at Adire Audio comparing the t/s parameters with excursion of the Brahma and Audiomobile Mass (a standard SGLC motor). On the bottom, they show Qtc of each sub for excursion in the manufacturer recomended enclosure of 1 cubic feet each. Both seem to have a flat curve with little change. But when you look closely, you see that the Mass's Qtc changes .8 at only 20mm of excursion (from .99 to 1.7). The Brahma has changed maybe .1. Now let's see how audible this is. How audible would it be to go from a .7 to 1.5 Qtc? Probably fairly audible. But the change would mostly be in frequency response. Sure it will sound boomier, having a Qtc that high. But I think that higher Qtc's are more because of the frequency response change (like what Seth mentions earlier, but at a lower frequency section making it sound more boomy), rather than anything else. I'm curious what it would sound like if you took a Qtc like this and EQ'd the sub back to a .707 response. Would the difference still be audible?
    I remember asking Justin Weaver how much he thought we could change the box size before anyone would really notice. He said probably around 40%. That's a large change (to Qtc as well, especially if the sub needs a small box to begin with) before you could actually hear a difference. So that's why I think Kms nonlinearities add less audible distortion than BL nonlinearities.
    Kippels site shows the BL distortion being much larger than Kms and Le distortion. But I don't understand why. The only thing BL nonlinearities seems to effect is SPL. So output to power input becomes worse and worse. But how does that add distortion? I suppose this would effect the frequency response as well since the sub should be getting louder to keep up with the midrange, but it doesn't. But that should be much less than how much Kms effects the frequency response. Also, how does BL nonlinearities add sonic distortion (becides effecting frequency response)? From what I have heard (Brahma compared to a/d/s/ subs, IDMAX, etc.), it seems to add some. Where does it come from?
    I hope my ramblings here made at least some sense. Plus I hope I didn't pull it too far off topic.
  9. Steven Kephart
    Well I've come across a B10. Care to donate? :D
  10. BlkX
    BlkX Full Member
    Well, i offered it to Seth since we both live in the same town. It would be a daily switch type thing. Sending it to you would involve shipping costs and going without bass for days, plus i wouldn't get to hear them side by side :). Sooo, unless you have something to give me to run for the few weeks that i'll be without bass, i'll have to say negative on that one :).
  11. Steven Kephart
    Yeah, I was more just kidding around.
    Now that I think about it though, my head unit recently decided to die. This means that I have no way of playing my stereo, and right now my B10 is sitting on the floor of my front room. I have no extra money to replace the head unit right now. I suppose if you guys are willing to pay for shipping (with insurance), I could let you guys play with mine for a while. You MUST promise to be nice though and not break it.
    One other problem though is that the guys at work decided to throw away the old box it shipped in (the B10 I have now was hand delivered by Dan himself :p ). So I will have to find something to be able to ship it to you guys. This may delay the possibility a little. But the offers still open.
  12. BlkX
    BlkX Full Member
    Haha, i'll let Seth decide on that one, i'm a poor, unemployed college student at the moment. If that changes (which it might soon, got an interview Thursday :D), then i might cover that for ya.
  13. Justin W
    Justin W Full Member
    Food for thought...
    The overall argument is that the reason for the punchiness exhibited by some woofers moreso than others may possibly be due to the difference in BL curves...
    Just not sure about that...
    Look at this...
    http://www.adireaudio.com/Files/B12-10W7BL...mComparison.gif
    Posted by Dan Wiggins on CarSound a few months back. This is a normalized BL comparison of the B12 vs the 10W7. (Normalized means that the peak BL has been changed to 1 for both drivers).
    So really overall they look pretty darn even... W7 being flatter over part of it but falls off in the upper forward excursion range a bit premature of Brahma. They tend to fall off at the same rate though... roughly. Also the peak BL of the B12 is in the upper 14's while the 10W7 is in the lower 11's.
    Still... this variance here is apparently inaudible so for the argument it can be said that they are pretty much even.
    If anything on what causes this punchiness (within the case of the argument) I have to think it's got far more to do with installation specifics. Cabin and enclosure having a large effect on the response of subwoofer... the other factor with using t/s parameters as any concrete indicator of transient response is their instability once driven into substantial excursion (5mm+) and with power (VC heating factor).
  14. Justin W
    Yeah, I kinda remember saying that... and I'll kinda stand by it. ;)
    I should clarify though...
    I believe I was referring to one of two situations...
    1. This is based on your average install with your average listener. I believe this is more true with the larger the enclosure... as you get into drivers that work well in tiny enclosures you would be more apt to notice a 40% increase or decrease in enclosure volume.
    2. The other case where this is true is where your Qtc is already say at a relatively low point... say below .75. Make a +40% change in enclosure size and where does your Qtc go? Well, it doesn't go down much... maybe from .75 down to .70... I think if you level matched those installs most anyone would have a hard time really telling a major difference there.
    BTW - that comparison above was taking a B12 in a 1.12cf enclosure (result: .75 Qtc) and upping the enclosure by 40% to 1.57cf... you result with a .70 Qtc.
    Now... honestly 40% changes when they are made to enclosures that are more in the 0.8~0.9~1.0 Qtc range seem to make more noticeable differences in response.
  15. Steven Kephart
    [/b][/quote]
    Yeah, I tried to keep it non-definite by paraphrasing you as saying "probably around" because anyone can find an instance where it isn't true (as you did).
  16. Justin W
    Yeah, I tried to keep it non-definite by paraphrasing you as saying "probably around" because anyone can find an instance where it isn't true (as you did). [/b][/quote]
    Steven,
    I'm with you... just didn't want to have to explain it later so took the opportunity to do it now...
    Werd.
  17. ajofscott
    ajofscott New Member
    Several questions must be asked when selecting any speaker element albeit woofer, mid or tweeter. What is my application? Open Baffle or Closed? How stiff is the driver of interest?
    Inductance of the driver isn't a tell all parameter for the driver. Less inductance means there is either fewer turns in the voice coil or a longer path length and/ or smaller area pole or a combination of all of the above.
    An axiom applies to all motors speakers included. a Motor is a Generator is a Motor. This means all motors exhibit generator action as well as all generators exibit motor action.
    While some may argue that the high inductance speaker is less punch...... not necessarily true based upon inductance alone. That high inductance motor will inevitable exhibit a higher running impedance than its DCR of its winding. The motor's current will be I=(Vin - Vgen)/DCR, and its useful power will be the resistance portion of the running impedance not attributed to DCR. Speakers exhibiting low Vgen will behave pretty much the same despite thier environment as thier running impedance is dominated by DCR. Speakers with high inductances will present a lower impedance in low volume closed baffles as opposed to an open baffle application as well as may present an undesirable power factor for the amplifier causing it to run hotter than it otherwise would.
    If any reader wishes to have the math worked out in terms of what a layman can measure with a digital multimeter, feel free to email me at thescottsva@hotmail.com. I'll gladly email you complete with equasions and a schematic for a test fixture.
  18. sandt38
    sandt38 Full Member
    It has been a long time since I saw this thread, but I don't recall inductance being mentioned in correlation with punch. Inductance is really an indicator of woofer speed, and a simple way to determine transient ability of a driver. It seems to me the initial observation was that of linear BL, moreso than the offtopic debate of inductance. I'd like to reskim the thread to see where this was all going, but I wanted to jot down my thoughts before forgetting where it was started.
    As far as the calculator... why not toss it up here so we can host it. That would be pretty cool.
  19. sandt38
    sandt38 Full Member
    Yeah, I thought that was where this was going. If you look you will see that in the first post. It seems to me that somewhere else a discussion was going on in which the LE was being stressed as the greatest determining factor of a punchy driver. But alas, I disagree. Please note, in listening to the Brahma (a low inductance driver) that punch is not as glaringly apparent. My feeling was the parabolic BL evident in most drivers simply allowed the driver more strength in the upper subwoofer frequencies where excursion is limited, compared to the lower frequencies where excursion must increase in order to provide similar or (in the case of linear BL :p ) hopefully equal output. ANother example is the W7, fairly flat BL, but a greater Le. It was my contention that due to the motor strength being linear, punch is somewhat reduced due to the drivers lack of accentuating the upper sub frequencies, or attenuating the lower (or in my opinion, only :) ) subwoofer frequencies.
    I just felt that listening to the differant "supersubs" and looking at the specs that the correlation seemed rather apparent. Maybe to put it more clearly, it seemed to me to be the only indicator of that charachteristic.
    Think of a home theater mid, ususally they offer very low LE and yet they are typically fatiguingly punchy (IMHO). We all know they are not too worried about linear BL too ;)
    Thanks for adding the information, it was most valuable. Hopefully you will look into the sticky above entitled "George". With your apparent level of knowledge you might find it interesting. I must say it is great to have another smart audio fella around. I hope you participate more often.
