Subsonic Filter
Discussion in 'General Car Audio Discussions' started by fb4076, Jan 27, 2004.
  1. fb4076
    fb4076 Full Member
    alright, any ideas of where I could get it cheaper?
  2. deyton
    deyton Full Member
    Infrasonic = Subsonic
  3. ScottS
    ScottS Full Member
  4. ScottS
    ScottS Full Member
    I also have a hookup on the PA 2500D referb.
    I can do for 250 each. And offer a 90 day warrenty. One of my buddies has a bunch of these at his shop.
    not 100% sure if they have a ssf
  5. fb4076
    fb4076 Full Member
    Well.... ScottS if you can get me that amp that would be sweet.... but... would I have to worry about blowing my subs.... they are 2-ohm 750 watt rated.....
  6. ScottS
    ScottS Full Member
    You must remember or learn that its not power that blow's your subs. ITs distortion.
    This will not blow your subs if you do not distort it.
    Email me if you want one
    AdireAudio@hotmail.com
  7. geolemon
    geolemon Full Member
    LOL :p [/b][/quote]
    Doh! :bag:
  8. geolemon
    Scott...
    What were those tube amps...
    Or rather, amps with tube preamps, that you were talking about at CES?
  9. ScottS
    ScottS Full Member
    Planet audio HVT series. Hybrid Vacume Tube
    I can get alot of the HVT2100 100RMS @ 4 ohm each channel. I sell 185 each
  10. sandt38
    sandt38 Full Member
    Linky?
  11. delvryboy
    delvryboy Full Member
    hmmm.....contrary to everything i have learned
    only 2 ways to blow a speaker, mechanically and thermally
    neither of which are related to distortion, unless, you are talking about amplifier clipping, which in reality, can lead to overpowering
    on another note...those amps are mono correct?
    so i will need 2 for my front stage?
    and how long will you have them for?
  12. peter_euro
    peter_euro Full Member
    and how long will you have them for? [/b][/quote]
    In my limited experience, I have learnt that two things that kill speakers are ignorance and carelesness... :rolleyes:
  13. ScottS
    ScottS Full Member
    Cliping is distortion. If you clip your deck but your amp is properly "gained" will calls a Square wave if you will causeing the coil to "THERMALLY" heat up. Then BOOM there goes a coil Or shall i say a burn coils where your woofer becomes BLOWN like a fuse
    As for the 2500D its a mono amp for subs only 2500RMS @ 1ohm
    As for the HVT series they are 2 channel.
    And SandT If you find a link let me know. I have not been able to fine a picture of these on the net.
    HVT7150 is what i run. 150 rms each channel 4 ohms
  14. fb4076
    fb4076 Full Member
    what is amplifier clipping, I hear that term all the time, but I am not sure what that is...
  15. delvryboy
    HVT7150 is what i run. 150 rms each channel 4 ohms [/b][/quote]
    okay, i was under the impression that the additional heat caused by the square wave(clipping/distortion) would have a minimal effect, and the power increase due to the clipping is what causes the thermal failure....i guess i have been listening to totoro to much....
    i was referring to the hybrid tube amp...i don't know why...i was under the impression that they were mono amps...so i would need 1 per side
    i am definatly interested in running one of these...how long do you expect them to be available to you?
  16. ScottS
    ScottS Full Member
    well honestly I expect atleast another year.
    Scott Stoner
  17. sandt38
    sandt38 Full Member
    Do you know what a clipped waveform looks like? If so, realize that the cone is moving just like the waveform looks. A typical unclipped waveform has greater movement, where a clipped waveform has an almost DC waveform (I know, it is not DC, but basically it has an "on" time rather than a progressive slope). It is this on time, and reduced movement that helps generate heat, and reduce movement of the driver limiting it's cooling ability.
    As I am sure you can see, reduced cooling, and the additional generation of heat can lead to thermal failure.
  18. hobbes26
    hobbes26 Full Member
    but say you have a square wave
    current is proportional to acceleration
    so the sub wouldnt really stay at the top of the wave
    then move to the bottom of the wave
    i.e., the cone is not gonna stay at max excursion for the
    flat part of the wave
    it's going to try to move at constant acceleration in one direction
    and then constant acceleration in the other direction
    not varying acceleration, as in a sine wave
