no those r my EHQS's that i put in there to give u an idea and its a 40x2 jensen amp that came in the car. i know, the box looks like crap, it was just an experiment.
just wondering if you know the box requirements of the PB subs that you want to get? I'm sure you'll be able to get 4 in there, prolly take up most of your trunk space though.
Those PB 12's only need 1.5 cu ft ported. So the box will fit. The only way I would fire the port through the rear deck is if you semi wall it.
say you build a box like this with 4 12's. stiffen the rear deck and you can have the bass come in thru there. this guy had his 18's firing thru his rear deck, and it pounded. dont have a pic of the deck tho
so i could make a prted box like that bandpass one minus the sealed chamber and seal the rear deck and use a vertical piece of would as the face of the box and another connecting the face to the deck, insert the ports through the deck and use the floor and walls of the trunk as the other sides of the enclosure... right?
wont me my first encounter w/ fiberglass, i used to work in the hvac field.....insulation is a bitch. not to mention this isnt my first time tinkering with fiberglass enclosures thanks though!
PowerBass PB-104DV.2 Four 10 Inch Dual Voice Coil Subwoofer 250 Watt Car Sub 10†DVC 4 Ohm PowerBase: Powerbass PB104DV2 [2PAIR] SUBS V1 CA TheDeepDiscount check this out. pretty cheap.
my bad, i thought that jonnyv713 said he was going to do fiberglass. guess i had one of my moments, wasn't paying attention.
i was also thinkin about 2 of these in this kind of setup JBL GTO1504D (gto1504d) , Component Subwoofers, 15" Component Subwoofers - Sonic Electronix but then again i would have more cone are on the 4 12's
hmm....i got my PB-B156DV.2 from him, i paid 60.00 shipped for the pair, they were loud as fuq, almost as loud as my rhinos they were shipped same day, and customer service is awesome, i guess its like wal-mart.....they got good stuff...then they have garbage, just gotta watch what you buy
ok what do u guys think about this? (im bored and have nothing else to do) 2 of these Cerwin-Vega V-Max124 (cer-vmax124) , Component Subwoofers, 12" Component Subwoofers - Sonic Electronix with Hifonics TXi 1008D (txi1008d) , Car Amplifiers, Mono Subwoofer Amps - Sonic Electronix
I got two 10in Cerwin vega V-max subs in a small sealed prefab that is like almost 1cuft per chamber and they are running off of one of these... MB Quart RAA4200 at 4ohm bridged... and they hit pretty well. once I get some money to make a ported box I will make a vid or something to show you what they can do.
well they need a bigger box... and they are in mercedes benz where the trunk is completely sealed off from the cabin... and they hit as hard as my other brothers kicker cvr 12's did... they are built quite beefy. so I can say comparable or better than cvr's but I dont know if they are L5 or cvx worthy. if I can design a box where the port can go through rear deck I would be able to tell you how good they are. they handle the 400 watts a piece like nothing.
