sub box for a kicker 15 l7
Discussion in 'Subwoofer Box and Custom Fabrication' started by magnum340, Aug 13, 2006.
  1. pedro quiroga
    the kicker L5 10 i have has poly fill in it.it's a kicker box.granted its for a truck.(sooo tiny)but it sounds great.deep and tight.sounds killer with jazz and country.DEEEEP.so then whats wrong with using poly fill?oh and im way underdriving with like 250-280watts 8ohms. mono.so then why not try a 10 or 2 8s.they sound awsome and need a teeny weeny box.mine is .88cu ft.that leave tons of space in the hatch.trust me i know.i go on trips with three dogs,and a 5yr old,(sub off)they stay in the hatch.so good luck with whatever u pick.
  2. aznboi3644
    Smaller box - higher F3, peakier...polyfill is a bandaid for not having enough space
  3. pedro quiroga
    well it is a truck box.behind the seat type.it was made by kicker for that sub.so it has to be small.so in a bigger box it will have more output?but arent these subs made for small enclosers.
  4. Hautewheeler
    Hautewheeler Full Member
    YUP AZN.. bandaid.. not a fix.. does help some, and in kicker's defense, there are usually SERIOUS space constraints with behind-the-seat sub enclosures.
    like I said.. if you have the space, build it big and ported, and forget the polyfil. if you don't then go sealed, they won't take up that much room in a properly built and designed sealed enclosure.
  5. magnum340
    magnum340 Full Member
    oh, what the hell ill just build 2 boxes one of each. mdf is only 20$. as of now i think im leaning twards the 12 l7, and build both boxes as big as they need to be, witch is still smaller than the minimum air space for the 15. my last system was 2 15 fosgates hx2 in a cougar. ill be in a hachback this time and i hope i wont be disapointed cuz i still remember how my 15s pounded! do you guys think theres a big diffrence in a trunk and hachbak? 2 15s -1 12 if im making a mistake (in your oppinion) please let me know!
  6. Hautewheeler
    IMO 2 10's (bandpass) in a trunk sound like
    2 12's (ported) in a hatchback
    hatchbacks are fantastic for back of your head noise, but bandpass in a trunk is great for neighborhood resonance..:D
    and nothing compares to 15's
    except 18's
    and 22's
    and 24's
    etc..
  7. aznboi3644
    Well yes...do you ever see small boxes in spl comps???
  8. Hautewheeler
    well put azn.. right to the point
  9. magnum340
    ok felas first of all thanx for all the usefull info, and i geuss this will be my last question to all this mess and then i will decide. my max size box that i will build weather its a ported or seald will be a 3 cu ft. wich sud will sound better in that air space 15 or 12 l7 ? one more thing how do you tune the ported box? whats the formula?
  10. aznboi3644
    With 3 cubes...depends on the driver...I'd lean toward the one 12 L7
  11. pedro quiroga
    he did say he wanted room in his hatch that is why i recomended a smaller encloser/sub.and no i have not seen any small boxes in spl contests.also no passenger space either.lol.i chose the small box for its size and output,but mostly size.
  12. aznboi3644
    Well If he wants to keep some room than I'd say look for drivers that are actually designed for small sealed enclosures...like plug the numbers into WinISD and see what the response would look like.
  13. magnum340
    well dose anyone ells have any more info or suggestions?
  14. aznboi3644
    with around 3 cubes...you can either go one ported 12 or on sealed 15...either way it's still gonna slam...I'd do the one 15 sealed
  15. Hautewheeler
    my man, my man.. are we related? - I like the way you think!:D
  16. aznboi3644
    Great minds think alike... Hows Terre Haute doing???
  17. aznboi3644
    Damn computer F'ed up and posted it twice...So ima edit this one to say.
    So what box and sub are you going to choose?
  18. magnum340
    well guys just thought id let you guys know im gona get 2 10L5. i know this wasnt even an option earlier on, but its about the same price as the15l7 and less air space. i hope this is the best setup ( for me ). thanks again for all the info and help it was much apresiated.
  19. pedro quiroga
    i think..no i know you will be happy with the 2 10s.i have 1 and am looking for a new box for it.to maximize its output.dont get me wrong.it slams now.i know it can do better in a slightly larger box.not wanting to thread jack,but is 100 to much for a custom box?nothing fancy.just a rectangular shape box.24x9x13.give or take.
  20. aznboi3644
    Not sure...but for less than 100 bucks you can build yourself a box...and you wont have to go without a car cuz its in the shop...Plus its a good experience
