software
Discussion in 'Subwoofer Box and Custom Fabrication' started by electrolytic, Mar 5, 2007.
  1. electrolytic
    electrolytic Full Member
    130db lol, that should do me just fine, i think this sub performed the best of all. So that's what like 180 db with cabin pressure HAHA, ok maybe 143db?
    @36.5hz
  2. aznboi3644
    well...you can't really accurately tell how high you'll high on the meter.
    Being loud to the ear and meter are two different things. A box can be designed to meter high numbers but can sound twice as quiet as a box that is designed to be loud to the ear. For example Hexibases Hellboy...it only metered like a 146-147 compared to a pure fart box that metered 149.6 on the meter but didn't sound anywhere as loud as Hellboy
  3. electrolytic
    ok, i don't want it to sound loud to the ears, i want it to be like i'm at a concert loud standing way back lol. Is 6 cubic feet good for that.
  4. aznboi3644
    For the 13Av.2??? If so that is way too big
  5. electrolytic
    That's what all last the pics are of.
  6. aznboi3644
    yeah...6 cu ft is wayy too big for that sub. It would not be worth is wood, time, and space
    6 cu ft with two 6 inch round ports 15 inches long would get your tuning around 35-36Hz. This box would be pretty boomy and not as good sound quality.
    I'd stick with between 2.5-3.5 cu ft
  7. electrolytic
    hmmm, ok i ran it through again.. 3.5 cubic feet is too small according to bassbox, you can see in the picture the dark green line is the best at the bottom, i went from 3.5 cubic feet and up until i got this. 6.5 cubic feet total @40 hz
  8. electrolytic
  9. electrolytic
  10. electrolytic
  11. aznboi3644
    what do you mean???? Bassbox says it is too small??
  12. electrolytic
    The excursion and vent velocity are too high at that size, no matter what kind or size vents i try. 132db @ 41 hz
  13. electrolytic
    post #207, the purple line at the top is 3.5 cubic feet
  14. electrolytic
    are you using 800 watts for input power? and 1200 watts for the sub's power handling
  15. electrolytic
    the last pics are the best i can get, smallest.. it hits the loudest @41hz now, unless i still have something wrong..
  16. Ranger SVO
    Before I talk about cone displacement remember that many of the rules I use are generalizations that I've come up with over the years. If your a gambling man then bet on them, but they are not 100%.We saw that with the Team Rockford Woofer. My rules did NOT work and I spent a couple of hours trying to figure out why.
    Now cone displacement, if we are exceeding the woofers Xmax at 20 Hz we DON'T have a problem. There is no music that low. Sorry, didn't mean to hurt anyones feelings. In fact there is almost no music below 30. Get over it.
    Now lets look at my sons cone displacement. He listens to Rap, Rock and Country, he listens to it all. He is a typical teen and he beats his woofers hard. But so far we have never had a problem.
    His woofer maintains control to about 32 Hz (I would have prefered upper 20's) and yet we have never had a problem, so none of the material he plays is causing the woofer to exceed their limitations.
    Notice the dip, thats were the port is tuned. Isn't that cool how we can see that. Also notice that the graph changes color when we exceed the woofers ability
      File size:
      76.6 KB
      9
  17. aznboi3644
    I am using 1200 watts rms as the input signal.
    Vent velocity for me doesn't exceed like 67 ft/second with a 3 cu ft box and a 14 by 4 inch vent tuned to 35 hz...sub doesn't go out of control until 25Hz also...as is well
  18. electrolytic
    hmmm, strange, i wonder what is causing such a big difference in results. Only thing i can see is you have 34 inch vent, Let me try again see if i can get 3.0 cubic feet. With 1200 watts too i was using 800
    oh and @ 1 ohm your running, you think that poor ed amplifier can take it LOL
  19. electrolytic
    how many watts are you rating the subwoofer at, it says 1200-1500 i think.
