Question....
Discussion in 'Car Stereo Amplifiers' started by Eclipsed, Aug 7, 2006.
  1. aznboi3644
    Not necessarily...more power yes...more heat and potential failure if your amp cannot handle a heavy abuse at that load
  2. Eclipsed
    Eclipsed Full Member
    I'll run it at 4 then.
  3. CadillacETC1997
    true the lower the ohms the less resistance there for more power passed on to the sub. however the higher the ohms the better the sound from the subs and less potential of overheating or frying the amp.
  4. Eclipsed
    So, 4 ohm is the way to go, not to much power, not to less power....?
  5. aznboi3644
    Too much power?? haha
    Too less power?? if you want
    what is your amp rated at??
  6. CadillacETC1997
    4 ohms is the standard for like day to day use and reliability. 1-2 ohms is for competition.
    as azn said too much power... no such thing, but before id run lower than 4 ohms and expect good sound and reliability, id buy an amp that pushes more watts out at 4 ohms.
  7. weird22person
    weird22person Full Member
    Get the 4 ohms. Wire them series for the coils and parrallel subs. You end up with a 4 ohm load. 4 ohms is pretty much the standard and you cant go wrong with it. Most amps are designed to preform the best at 4 ohms.
