ported box for 2 15" audiopipes
Discussion in 'Subwoofer Box and Custom Fabrication' started by danracer, Aug 2, 2007.
  1. danracer
    danracer Full Member
    can i put 4 4" ports with a lenght of 8.739???
  2. Ranger SVO
    Four 4-inch ports is really close in size to two 6-inch ports. We are only talking about 5 sq in of surface area difference. (yes, two 6-inch vents is still a little larger)
    The difference is minimal so you can use four 4-inch vents.
    You might even consider a slot vent. As long as the surface area (the area of the opening) is about 55 to 58 square inches the length will remain the same
  3. danracer
    yea ill pobably use 4 4" cuz i didnt find 6 inch pvc pipe
  4. danracer
    i just got the wood, its already cutted. all i need to do is mark where ill put the subs, ports, and terminals. and then start to assemble
  5. Ranger SVO
    Take your time and it will turn out good.
  6. danracer
    is there gonna be a big difference in sound between the sealed and the ported one??
  7. Ranger SVO
    Absolutely, the ported will be louder. There is a thread here somewhere where someone documented the building of a ported box. It would be a good idea to check it out. In fact I'll go look for it.
  8. danracer
    ohh its that the speaker circles didnt come out that cicle at all...lol
  9. Ranger SVO
    Check out this thread
    http://www.caraudiotalk.com/audio-forum/subwoofer-box-custom-fabrication/5250-kicker-cvr12.html
    Go to pages 10 and 11, he is using a slot port. Which is what I suggested considering instead of trying to cut 4 round holes for the port.
    But all is not lost. Put the ports in using either 3/4 or 1 inch screws. And then use silicon to seal it up from the back side. If you look at the pic I posted earier you should be able to make out the screws in the port.
    Or it might not be too late to switch to a slot vent.
  10. danracer
    what measurements do u think the slot vents should be??
  11. Ranger SVO
    Tell me again what the final dimensions of your box are and I'll get back with you shortly.
  12. danracer
    are these measurements good?? 20.5 height, 1 inch width, 3.28 lenght??
  13. danracer
    the final dimensions are 22 tall, 45 wide, 16 depth
  14. Ranger SVO
    OK lets give this a try, we need a slot that is 20.5-inches tall by 3-inches wide. The port needs to be between 7 and 8 inches long to get you around your 37 Hz tuning.
  15. danracer
    hmmm a port that wide the program says it ill be 12 inches
  16. danracer
    would 2 inches wide work"??
  17. danracer
    hmm i think i might have something wrong here...now it tells me the spl can be 145 dB
  18. danracer
    what i did was that i took the braces out
  19. Ranger SVO
    Well lets see. I do make mistakes.
    We have an inside area of 7.5 cu ft (I'm rounding off), we are gonna subtract about a 1/2 cu for the port, that leaves us with an internal volume of 7 cu ft
    Now a port that is 20.5 x 3 has a cross sectional area of 61.5 sq in which is equivelent to one round port with a diameter of 8.85-inches
    Actually we were both wrong, the port needs to be 10.79-inches long. Just shoot for 11-inches. I made a mistake with the calculation but your result should still be closer to mine. BassBox can take into account things that I can not. But our results should still be closer.
  20. danracer
    ohh ok...well found the dB problem...it was set to volts instead of watts...can i do a 2 inch wide port??
