ported box for 2 15" audiopipes
Discussion in 'Subwoofer Box and Custom Fabrication' started by danracer, Aug 2, 2007.
  1. danracer
    danracer Full Member
    how many foots of cable do i need for the big 3?
    well going from 135 to 300 each will get you at least 2 or more db's.
  3. danracer
    okk thats not that bad...and would the big 3 gain me dbs?? or just for current stability?
  4. aznboi3644
    the big three in some situations can help...it can raise the voltage that your amps see making the amp work not as hard and more efficient
    I'm loading up a couple vids of the 12W6 and 400-500 watts
    one is a 10Hz Tone....sounds like a helicopter lol
    the other is a 35Hz tone...both are the with engine off amp seeing about 12.6 volts
  5. danracer
    okk well then ill do the big 3, hook the subs @ 1 per channel, what else should i try?
  6. danracer
    which battery do u have on front?
  7. aznboi3644
    Duralast Gold Group 65
  8. danracer
    how many amps should a good battery be??
  9. aznboi3644
    well mine is like 1000CA and i think 875 CCA
    I always say just get the biggest battery you can afford
    reserve capacity is good too...i forget
    Here is 10 Cycles
    Here is 35 Cycles
    Here is 40 Cycles
  10. danracer
    lol i gotta do the water bottle test on my van...anyways...at 10 cycles the sub has a loot of excursion damn
  11. danracer
    is it easy to fit another car's battery in another car
  12. aznboi3644
    yeah...fairly simple.
    read the sticky about adding another battery in the electronics section of the forum
  13. danracer
    hmm...what im saying bot a another cars bat i mean like put a pathfinder battery in my quest
  14. aznboi3644
    why would you do that??
    if it fits in the battery tray than the swap should be simple.
    Most factory batteries are just big enough to start the car and run some accessories...unless you have a big truck
  15. danracer
    its that there arent any optimas for my quest so i wanted to see if any other batt would fit, but do u think im better w/ the batt i have now and a gel batt in the back?
  16. danracer
    and if i put an optima battery which one should i put red top or yellow top?
  17. aznboi3644
    really either batteries will work fine
    the only major difference between a starting battery and a deep cycle is the thickness of the plates.
    I'd go for the yellow top though...it is warrantied for audio use also.
    i'd keep the battery you have now and add an optima in the back
  18. danracer
    hmm ok...its that there is a guy on a local forum selling red tops @ 65 bucks
  19. danracer
    and i can also get yellow tops @ 99 @ a local shop....
  20. danracer
    my amp has 3 cross over settings, high, low, full which should i put it at??
