OHM help
Discussion in 'Car Subwoofers' started by footsteps951, Aug 16, 2007.
  1. aznboi3644
    the mono amp just has 4 output terminals...not 2 channels
    can you take a picture of the wiring you are talking about
    the top diagram is how you should have it wired
    Subwoofer Wiring Diagrams
  2. footsteps951
    footsteps951 Full Member
    ya
    thats how i want to have it wired
    but is it okay to put a hole in the box to be able to connect the wires
  3. aznboi3644
    yeah its fine...you can drill a hole...run the wires...then seal it up with some caulk
  4. footsteps951
    oh okay.some caulk
    kool
    alright so that would be better to run them like that then using a 4 ohm setup
    another thing
    im using all four terminals on a 4 channel
    im not sure which 2 to use once i change the setup to 2 ohms
