i found an amp locally and its a jensen 150 for twenty bucks i wanted it to power my ehqs 12s until i get more money is it worth it
hell yeah for 20 bucks its worth it...if not than you only lost 20 bucks. it should power one the speakers fine for now....they are pretty efficient
well i bought the amp for fifteen it is a 115 rms 340max jensen pro model number ps260 i think it is a pretty good amp
4 cubes tuned to 30-35 Hz will do perfectly. I had one ehqs 12 in a 1 cu ft box tuned to 30Hz..yeah it was a box I built with scrap wood for a couple 6.5 inch subs...just glued on another baffle and cut a 11 inch hole for the sub...it actually sounded decent off 300 watts. But that was severely choking the sub
alright thanks. now i have a problem with my old deck its a sony cdx-1300. it will play the amp off the rca's but all the speakers off the harness wont work. is it time for a new hu? or can i fix it?
Im not sure if fixing a head units speaker outputs are worth it...unless its brand new than it is under warranty...are the outputs full range?? Do you have an extra small amp laying around to power the speakers??
well...you can get a new pretty nice HU off ebay for pretty cheap I'ma get a Pioneer 590 off ebay for like half of what it costs at a local store
ok i bought the wood and my box is gonna end up being 4.07292cu feet i want to tune it to 35hz should i use 1 or 2 4 inch ports that are 4 inches long firing to each side
use two 4 inch round ports each about 12 inches long that would give you tuning around 33-34Hz which should be good
i just ran the box through bassbox pro and the numbers i come up with is different than anzboi. here they are: to tune at 30hz 2-4" ports 48" long, 35hz 2-4" @ 34" long, and 38hz 2-4" 28" long. 30hz 1-4" port 22.5" long, 35hz 1-4" port 15.5" long and 38hz 1-4" port 12.5" long. All with a box net of 4.0 cf. Can someone check me to see if i made a mistake?
yup those are wrong...I'm not sure why your numbers are off with a 4 cu ft box and two 4 inch round ports 48 inches long tuning would be 18Hz
