New system in my new car!
Discussion in 'General Car Audio Discussions' started by jonnyv713, Mar 23, 2008.
  1. jonnyv713
    so electro, what do u recomend?
  2. electrolytic
    electrolytic Full Member
    huh? lol i don't know, i'm just saying don't overpower that sub they are touchy. Get an amp that pushes 600-750 watts rms @ 1 ohm no more.
  3. cccullen
    L7 15" is 1000watts rms.
  4. electrolytic
    oh cool, my bad..
    Kicker 06S15L74
    Subwoofer Size 15"
    Impedance 4 ohms
    Dual Voice Coil Yes
    Peak Power Handling 2000 watts
    RMS Power Handling 1000 watts
    Woofer Surround Santoprene Rubber
    Woofer Composition Titanium Deposit Impregnated Cone with Rolled Outer Edge
    Sealed Box Volume 1.5 - 6.0 cubic feet
    Ported Box Volume 3.0 - 6.0 cubic feet
    Sensitivity 89.4 dB
    Frequency Response 18 - 100 Hz
    Xmax (millimeters) N/A
    Top Mount Depth 8-1/2"
    Cutout Diameter 14-1/16"
    Warranty 1-year Manufacturer's
  5. cccullen
    you think it's still too much power for the L7?
  6. jonnyv713
    well my dad came home and he said the car was pretty much junk, so i was lookin in the news paper and i found a red 1966 impala: red, runs but doesn't drive, very nice, needs TLC, for $800. so i think i will call that guy tomorrow. i am thinkin something is wrong with the drivetrain, transmission or rearend probably. if i spend $700-800 on the car and about $200-250 on a tranny i can have a nice car for around $1000. and a base for a nice system. that is another thing, if the car needs a tranny, there is one right next to it in the paper: rebuilt TH350 with B&M stall converter. so i think i will have to check all this out tomorrow. and what do u all suggest for an amp for the L7?
  7. pedro quiroga
    why not find a car that doesnt need work?
    how much can you spend for the amp/sub combo?
  8. electrolytic
    Maybe this.. I've never had a 15" kicker only 12's and 10's and they are 750 watts. 1000 watts should be perfect though.
    HIFONICS TXi1008D <br>MONO-Channel TITAN Series Class-D 1000W AMPLIFIER
    HIFONICS TXi1008D
    1-Channel Mono-Block Operation
    XP Class-D Amplifier Topography
    Rated Power :
    1000 W x 1 ch @ 1 ohm
    700 W x 1 ch @ 2 ohms
    350 W x 1 ch @ 4 ohms
    Ultra-Fi MOSFET Outputs
    Illuminated Hifonics Logo
    PWM MOSFET EXVP (Exponential Vari-Power Supply)
    SPC Twin Turbo-Torroids with Simpatico Coil Design
    Fully Adjustable Accu Cross Crossovers Include :
    - 24 dB Subsonic Filter ( Adjusts 15 Hz to 35 mHz )
    Phase Shift Adjustments ( 0 to +180° )
    24 dB Low-Pass Crossover ( Adjusts 35 Hz to 250 Hz )
    Bass Boost : Variable Bass Equilization ( @ 45 Hz )
    Remote Bass Boost Control Included
    Balanced Line Inputs with Optional MM-BLD-1
    RCA Line Outputs :
    Permit Amplifier Daisy-Chaining
    0.2 V to 9 V Signal Level
    4 Guage Power Connectors
    "Power From the Gods" Included
  9. jonnyv713
    i could prooly spend $400-500, and i love to work on cars and i am on a budget. it is just what u find around here. an the impala would be that car that gets the restomod type treatment. so i would keep it for probly forever.
  10. electrolytic
  11. jonnyv713
    well that amp looks good but for about the same price i can get a bigger one and turn the gain down. is that 1000 watts max?
  12. electrolytic
    it's 1000 watts rms, that's the true power, it will match your sub's rating perfect.
  13. jonnyv713
    but i was also thinkin about the Nine.1 now too. that would be soo bad as! lol but that is 200 more watts RMS. but the Nine.1 is underrated too, so it will prolly be even more so idk. and on that Hifonics it says 1000 on the case and usually on the case, it says the max, doesnt it?
  14. pedro quiroga
    then do a nine.5.
  15. jonnyv713
    thats only 600RMS at one ohm
  16. electrolytic
    he probably meant nine.1
    This is rated at 12.5v so it is underated, nice amp but it may be too much for the kicker, i wouldn't do it lol, that would be about 1400 watts rms or more..
    Elemental Designs
    Model Name : NINe.1 Amplifier
    RMS Power @ 12.5v : 1200 x 1 @ 1Ohm
    900 x 1 @ 2Ohm, 450 x 1 @4Ohm
    Elemental Designs
  17. jonnyv713
    ya prolly way too much so y not the hifonixs 1606D or whetever it is? and then just turn down the gain? or could i just turn down the gain and have an amp if i ever decide to upgrade to a bigger sub.
  18. cccullen
    that would be too much for the kicker at 1ohm. you could do the nine.1 at 2ohms though.
  19. jonnyv713
    what about the MTX? or is this too much too?
    wow i just realized how much power u get when u spend over $200
  20. pedro quiroga
    no i meant the nine.5 . i heard it can do 700-800 with a good electrical upgrade. meaning a big 3.and it wil power your whole system.
    its capable of doing 500 x2 on the 4 ch section.thats what i read.
