My New Subs/box
Discussion in 'Pictures and funny Stuff.' started by pedro quiroga, Feb 28, 2008.
  1. cccullen
    JL, man i'd love to have one of them. can't afford it now though. That's what i really wanted.
  2. electrolytic
    electrolytic Full Member
    This is what i'll do for my 10 fans and my distro block's digital readout lol. OEM SPDT Relay + Socket 12V DC 30/40 AMP Bosch Style - (eBay.ca item 220205481223 end time 05-Mar-08 02:43:09 EST)
    GREAT FOR ADDING ALARM, DOOR LOCK ,HOOD LOCK, TRUNK RELEASE, SHAVED DOOR HANDLE, LIGHT FLASH, HORN HONK, SWITCHING 12VOLT TO GROUND, INSTALLING FOG LIGHTS ETC.
    ALL RELAYS COME WITH HARNESSES (16 ga wires) AND ARE FOR 12 VOLT APPLICATIONS. THESE ARE PERFECT FOR USE WITH ALL TYPES OF 12 VOLT CAR SECURITY SYSTEMS
  3. electrolytic
    lol, this site doesn't like ebay links, what's up with that? Anyways you can punch it in they are like $8.00 delivered. Or just go to a local auto supplies store.
  4. electrolytic
    I'll be using my relay backwards though lol, i need the negative to be switched.
  5. aznboi3644
  6. pedro quiroga
    ok.the last time i used my big fans i didnt use a relay.
    im going with out fans right now cause i re wired the amps again.
    the 4ch is running the subs and its in the open.so it cools off better.
  7. electrolytic
    I'd rather have the plug in case it ever needs to be changed and it's a cleaner install.
  8. cccullen
    I do know what fans to get and how to wire them up but i'm just wondering how it should look under a false flooring (for the push and pull effect). I've been trying to find pictures but i haven't had any luck.
  9. pedro quiroga
    well i found out why those little fans were killing my amps.they are rated at 1.8 watts and the other was 1.6 watts.
    my 3 in fans are .16 amps each.all 12v. thats why the bigs ones ran fine when i had them in before.
    oh yeah...i also did a complete rewire under my hood.cost me....126 bucks.ouch. turns out my batt terminal that ive had for almost 18 years wasnt clamping onto the batt post like it used to.
    so it cost me 56 bucks for 2 new ones from CC.i know i payed retail,but it was the cheapest in town and they are very solid.
    my under hood fuse was also falling apart.thats how i knew somthing was a miss under the hood.it just literally fell apart.i guess you do get what you pay for,and i payed 5$.i needed one quick and it was cheap.
    i also had to replace my power from the batt to the fuse.the fuse box wasnt to bad i think.it was 30 bucks at BB i had a 5$ off coupon.its a rockford and it is stout.
    i also beefed up the grounds under the hood with some wire that i had left over.it was 8 gauge so i doubled up for now. cleaned up the frame a bit and installed them into an exsisting ground bolt.
    so when i started the truck my volt meter went way past the 14v mark and my digital meter was reading 14.9 volts.wow.it did settle down to a steady 14.2 after a few minutes.
  10. electrolytic
    expensive stuff!! Your gonna need it though to beat my 157.8db, when i get it hahahahahehehe
  11. pedro quiroga
    lol..
    i can just kick my self for not inspecting my cables for so long.:eek:
    as for the cheap audiopipe fuse holder.:mad:i should know better.
    so i made a short vid of it playing a 30-35hz sine wave then it goes to a40-45hz wave.notice how the voltage just stays rock steady,and i wasnst giving it gas.just at idle.
  12. pedro quiroga
    its uploading now.
  13. pedro quiroga
    ^^^^not revving the motor^^^
  14. pedro quiroga
    the motors a bit dirty.went camping this weekend
  15. aznboi3644
    inline fuse is too far away from the battery.
  16. pedro quiroga
    well when i get some more wire that will change.
    the wire going to the amps will have the fuse box over the moter.thats what most likely cause the old one to dry rot
  17. danracer
    danracer Full Member
    who needs fuses anyways lol :D nice box/subs
  18. pedro quiroga
    thanks.long time no see..
    well i just got back from fixing the problem.i forgot i had some slack in the power cable so i brought it up front.the fuse box is now 20 or so inches from the batt.i had to tuck it in the passenger corner of the engine bay to keep it away from the ecu,and a/c unit.
  19. danracer
    yeah had been a while since i last commented here lol hard to keep up with all the forums im in :)...i dont think that the fuse box will have anyproblems there cause i dont see how it can get pinched or short anywhere there i would tighten the cables tight so the dont fall and the cable touch the engine, and if you have some tiewraps or however they are called and hold the cable tightly with the other cables.... sooo... have you metered the new box yet??
