LOL!!! ijust caught that too!!!! wire it from the battery and not the rca cables??????? I am sure intentions are good, but ,no , makes no sense!!! whachutalkinbout willis?
Well...there is a myth that rca cables can carry more current than 4 awg wire...wait no I'm just making this up lol
ah yes! the wire runs of 4 gauge are far less supior to the 43 gauge wire in a rca patch cables...beins how the smaller diameter wire is capable of handling low frequency pulses as put out by the alternators ill effect of rectification in most factory electrical systems, this makes snese. I suggst a run of 22 gauge from the alternator to the amps power input to supplement the voltage potenetail of the internal capacitance, but at 18 volts instead of the run of the mill 13.4 volts in high currssssnt demand situations. then be sure to instal a bypasss switch on the negative of the alternaor input for "on demand" full feild and 38.34 volts of current to your amps tthrough the patch cables. ehich I am sure the patch cabls will handle at least 965 amps of currnt, for .1423 seconds, on a very good day....with alquida blowing off muy cactus in a rage of , porn infestedporn.... TY.........
