Kicker CVR12
Discussion in 'Subwoofer Box and Custom Fabrication' started by electrolytic, May 17, 2007.
  1. eazy
    eazy Full Member
    x2
    I'm always confused what you're referring to lol.
  2. electrolytic
    electrolytic Full Member
    all the graphs on that last page are for 4 kickers. one setup.
  3. electrolytic
    haha, ya i should write a paper how to burn a sub...
    I got two kickers now, two more coming soon, will post pics in a sec. Actually i'm not sure now if i have room for 4 subs, will be tight, this box barely fit.
  4. electrolytic
    Kicker CVR112 BaDDest on The Block haha, it pumps pretty good, blew an 80 amp fuse first run lol.
  5. electrolytic
    ...................... Orion 2100 Competition Amplifier
  6. pedro quiroga
    wouldnt...lets say 4 of those 13$ ED subs take the abuse?
    if wired into say 8ohms or so.since a really low load kills your subs too quick.
  7. pedro quiroga
    just checked the power handling for 4 of those.800 watts rms. maybe those wont handle THE BEAST!!
    what subs have you gone thru lately?
  8. electrolytic
    Haha, lets see, it's getting to be a long list. I had an Elemental Designs 18", burned, well started making a big noise on each bass hit, i think it was a mechanical failure on that one lol, about 6 infinitys, two kickers L5 and an L7, i just had a set of Kenwoods i have been using for a month or so and i just gave it back to my friend still working LOL, So i'm getting better. These Kicker cvr122s are good speakers and will be cheap to replace. I'm liking the idea of 4 of them more and more. I've never burned an MTX though, the only ones that survived my abuse. 4 of them is 1600 watts Rms so i'll have to take it easy on them when i drop to 1 ohm.
    I have it pumping big time on this one box now. Turned off the loudness on my deck, the bass way down, and bass boost off on my amp, then i turn it up!! Woooooooooooo, also this way the amp doesn't heat up as fast and it has plenty of bass.
  9. pedro quiroga
    so how many watts are those getting right now?
    i did a rewire some time back and am running my sub on around 200-220watts 40x2 for rear fill and around 275-300x2 for the front stage.
    i have my M50's running duel mono.one is left and the other is the right ch.i'm sure thats how i ruined my passenger tweet.i even had the gains all the way down.
    got nice and loud when i needed it to,with plenty of power for midbass. oh well.
  10. electrolytic
    Im running at 2 ohms so they are getting an underated 800 watts rms. Probably more like 1000, i guess i should take it easy on these too. Sigh.. It's like being locked in a candy store overnight but you can only eat one candy every half hour lol.
    I can send you a couple of these tweets if you want them, i won't charge you for them. Part of my ebay crap i've been holding on to.
  11. pedro quiroga
    thank you but i dont want to cut up my doors to mount those.
    i surface mounted the polks,and will most likely keep what ever i get surface mounted too.
  12. aznboi3644
    electro...I WANT A COUPLE TWEETS!!
    nah seriously though if you want me to send you like a dollar for a couple of them I can do it.
  13. electrolytic
    I can send you a couple no problem, they will be cheap to send so don't worry about it. I can probably do it this weekend. Send me a pm.
  14. electrolytic
    yes, no, maybe, lol For 4 kicker cvr122 subs
  15. electrolytic
    Actually it would be more like this, all one chamber inside the box for 4 subs. Good Idea? I'm trying to make it fit with my spare tire still accessable.
  16. pedro quiroga
    how about a big W shape.all facing forward.or two on each side.
  17. electrolytic
  18. electrolytic
    Still, waiting for my 0 gauge wire that i ordered so i haven't done anything yet at the back, but i just figured out that i'm killing both batteries with this setup lol. Most likely from my install and the inadequate wire but this amp is ridiculous. I think i may need a third battery and maybe a second alternator? LOL I have a good spot for one where the air condition compressor is. The AC doesn't work anyways.
    Maybe i should run 0 gauge from front to back instead of the 4 gauge that's there now. Sigh..
    If i go for a drive and pump the tunes for like half an hour then the voltage starts dropping to 11.3-11.6 while driving..And i got stuck at the gas station for about 20 minutes today. Wouldn't start.
  19. aznboi3644
    I'd definitely do a 0 gauge run
    my explorer would start even when the battery was at like 10.8 volts...I dunno why it was low that morning...totally random though...I woke up and decided to meter the battery....I was like wtf is it doing at 10.8 volts. but she cranked up just fine...didn't sound any different
  20. electrolytic
    I ordered 8 feet of 0 gauge for the back amp and battery connections, i should have ordered more grrr. lol, oh well i hate not having enough anyways, will get some more 0 gauge ordered.
