Kicker 750.1 amp...what kind of subs/box?
Discussion in 'Subwoofer Box and Custom Fabrication' started by eazy, Oct 8, 2006.
  1. eazy
    eazy Full Member
    Alright guys what do you think of this?
    By the way, winISD told me the port should be 19.16" and this website told me 18.32" so I called it 18.5".
  2. aznboi3644
    Looks good...If you have a router than round off the inside port edges...reduce port noise and smooth out the air flow
  3. eazy
    eazy Full Member
    Alright all these people have been telling me 12.5-17 sq. inches of port per woofer... but according to this website, a single 12" woofer with an xmax of 12.64mm tuned to 35Hz should have a minimum area of 24.24 in2.
  4. electrolytic
    electrolytic Full Member
    hey eazy, use winisd and build the box with exact measurements from winisd, otherwise it won't be tuned properly. Don't listen to any other websites. You can shorten the port length if you want by making the port bigger.
  5. eazy
    eazy Full Member
    Yeah, but winISD beta and winISD pro alpha were giving me and azn different port lengths (about 1/2" different) last time. But as of right now I'm trying to figure out this port area nonsense.
  6. electrolytic
    ok well 1/2 inch difference is probably ok, which subs are you using
  7. eazy
    eazy Full Member
    My setup is going to consist of...
    -a pair of kicker 400.1's powering a pair of cvr12's
    -a kicker 350.2 powering a pair of 5.25" cdt components
  8. aznboi3644
    .5 inches difference of port is only like a tenth of a Hz...it will make no difference...also their is end correction.
    Whoever said 12.5-17 sq inches of port does not know what they are talking about...graphing the port velocity with the power you have and the box a 12.5-17 inches of port per woofer will have pretty high vent velocity.
    Don't listen to them. I use WinISD to see what size port I can fit...usually I try to fit the largest port I can...Less port noise, lower port velocity...better
    Some people go by 12-15 sq inches of port PER CUBIC FEET
  9. eazy
    eazy Full Member
    You know what, screw it. It seems like the people on the lowrider site know less and less... even though I only listen to the mod and 2 other guys. I'm thinking a 2 chambered design. What do you think the best port area would be? The easiest would be 31... 15.5" tall and 2" wide.
  10. aznboi3644
    too small for two twelves...make that bish 4 inches wide
  11. eazy
    eazy Full Member
    I mean 2" x 15.5" for each chamber.
  12. aznboi3644
    that'll work...can you try to fit 2.5 inch wide ports??
  13. eazy
    eazy Full Member
    Well I kind of just went to lowes and had them cut my pieces lol.
    Do you think 2" is too small?
  14. eazy
    eazy Full Member
    I was thinkin this...
    If I did my math correctly it's 2.5341 ft3 + port displacement and sub displacement.
  15. aznboi3644
    you can prolly get away with it...it'll do perfectly fine.
    But I like big ports...not everyone does though. If you can make some 45 degree boards for the bends so the air flow is smoother that will help a ton. Distance from the middle of the 45* to the inner port corner should be 2 inches
  16. eazy
    eazy Full Member
    Well I'm 1/2 done building lol. In theory I should be done tomorrow. I'll take a couple pics of it right before I put the top piece on... so you guys can get a look at the ports and such. I'll also take some pics of it next to a basketball so you guys can get an idea how freakin massive this thing is lol. I'm going to have to reinforce that false floor. This thing is gunna be heavy as hell... no steroid-free thief will able to lift this out of my trunk.
  17. eazy
    eazy Full Member
    Well I'm heading up to the stereo shop today to get RCA cables, remote wire, 12" circles cut in my MDF, carpet, etc.
    EDIT: the bastards were closed... and parked their van in the doorway so no smash and grabs...
  18. eazy
    eazy Full Member
    Well I'm 3/4 done now. I cut the holes myself...they came out pretty good... besides the fact that they're 1/16"- 1/8" too small so I've been filing for 20 minutes and still no luck. Once those circles are the right size all I have left to do is attach the front pieces with the circles cut out, attach the top, do a little more caulking, and carpet it.
  19. eazy
    eazy Full Member
    Alright I took some pictures...
    I haven't actually attached the front and top pieces yet, they're just resting there.
  20. TheViking
    NICE job easy!!!
    That oughta rock your world!!!
