Kicker 750.1 amp...what kind of subs/box?
Discussion in 'Subwoofer Box and Custom Fabrication' started by eazy, Oct 8, 2006.
  1. eazy
    eazy Full Member
    The smallest rims my car can fit without grinding is 16"... otherwise I'd be rolling on 14" 100 spokes with whitewalls.
  2. TheViking
    So, you are a black boy then? one of the "brothers"
    Just givin ya crap!!!!!!! Whether you are black white or purple, I dont care!!!!!
    Its just fun to subject others to a racial profile and be wrong or even right....
  3. eazy
    eazy Full Member
  4. TheViking
    Ha Ha!!!!!
  5. armwifi
    armwifi New Member
  6. eazy
    eazy Full Member
    Well I was at the local stereo shop getting my alarm fixed yesterday and I was looking at amps...
    They had a kicker 100.2 for $99 ($129 installed) and a kicker 150.2 for $129 installed (didn't say how much not installed). I'm thinking about running an amp to my two 5x7's up front. The 5x7's are 60 rms watts. Do you think I should get a 2 channel amp to power the 5x7's?
    Do I have to worry about ohm loads like subwoofers? The 5x7's are 4 ohm.
    The 100.2 (rms) is...
    35 watts x 2 chan. @ 4 ohms
    50 watts x 2 chan. @ 2 ohms
    100 watts x 1 chan. @ 4 ohms Low Impedance Operation
    The 150.2 (rms) is...
    60 watts x 2 chan. @ 4 ohms
    75 watts x 2 chan. @ 2 ohms
    150 watts x 1 chan. @ 4 ohms
  7. pedro quiroga
    if crossed over properly the speakers should be able to handle the 150.2 amp.
    they both sound like they cost the same installed.129 each
  8. eazy
    eazy Full Member
    Yeah, what do you mean crossed over properly?
  9. pedro quiroga
    next to no bass going to your front speakers
  10. eazy
    eazy Full Member
    Oh, yeah I have my headunit set so there is as little bass as possible going to the speakers... and I have my treble all the way up.
  11. pedro quiroga
    haveing the treble all the way up is not the same as haveing the right crossover setting.
    does the amp have a built in crossover?
  12. eazy
    eazy Full Member
    # 2-Channel ZX-Series Power Amplifier
    # Low Impedance Operation
    # SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
    # MOSFET Power Supply
    # KickBass: 0-18 dB @ 45 Hz
    # Built-In Variable Crossover: 12 dB High or Low-Pass operation (50-200 Hz)
    # High & Low level inputs
    # PAST (PRE Amp Signal Transfer) Output RCA jacks
    # Custom tooled gold plated connectors
    # SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
    # Cast aluminum EndKaps
    # 60 watts x 2 chan. @ 4 ohms
    # 75 watts x 2 chan. @ 2 ohms
    # 150 watts x 1 chan. @ 4 ohms
    # Input gain control: Low Level (170mV - 5V), High Level (340mV - 10V)
    # Dimensions: 12-3/4" L x 10-1/8" W x 2.5" H
  13. pedro quiroga
    ok if you use the hipass out to your speakers and set the crossover right you'll be fine.go for the 150.2.
    are those new amps.?those models dont sound familiar.
  14. eazy
    eazy Full Member
    Well it says 06ZX150.2, so yes I'd assume so lol.
  15. pedro quiroga
    nevermind i looked them up.i'm familiar with their zx 750.1/450.2 and so on.
  16. eazy
    eazy Full Member
    Yeah, how do you think they'd install it? Run its own 4 guage power wire? Or use a distribution block at the end of the current 4 guage power wire?
  17. pedro quiroga
    hell if you can get it for 99.00 then do it.thats a steal.i'm sure you wont be dissapointed
  18. pedro quiroga
    i would ask,cause they would have to run cables for someone who had no amp right?and they will charge you for their wireing kit i'm sure.
    also what kind of install do you get for 29.00?you can do a way better job with our help.
  19. eazy
    eazy Full Member
    Yeah that's what I figured... I was just curious if they'd give me an amp kit and wire it all up with it's own power wire for $129.99... if so I'd probably let them do it... then fix it lol.
  20. pedro quiroga
    hey i'd love to help some more tonight,but i have to get up at 3am for work.
    i'm sure the GUY'S will chime in soon(azn,vik,dave,iban,ranger,and whome ever else i forgot....oh electro.and now whom ever else...lol)sup fella's.
