Kicker 750.1 amp...what kind of subs/box?
Discussion in 'Subwoofer Box and Custom Fabrication' started by eazy, Oct 8, 2006.
  1. eazy
    eazy Full Member
    Yeah they're all pretty ghetto rigged lol.
  2. aznboi3644
    very...I mean look at the amps and wiring for the pioneers
    Also those aren't even set up for good and loud sound.....just set up for "lets see how many we can stick in there"
  3. pedro quiroga
    ok. i got as far as disconnecting the rear fill amp.turned on the radio and it didnt sound the same with out my fill.
    so i dont think i'll do it.245watts is pleanty for me anyways.
    maybe someday......
    oh yeah very getto looking.
  4. eazy
    eazy Full Member
    Okay, when I put this box together...
    Should I use would glue and 2" coarse thread screws, then caulk the interior?
    Any tips for putting this thing together?
  5. aznboi3644
    Yes....I always PREDRILL the ends first and then screw em in a little bit so the boards wont move on ya....then predrill the rest of the length. Unscrew the ends, lay down some glue (I always spread it with my finger to cover it and then screw the sides.
    Screws should be 4 inches apart.
    The screws are only there to CLAMP the wood while the glue dries...Unless you have a good amount of clamps I'd just use screws...easier
  6. eazy
    eazy Full Member
    So when you're putting two boards together...for predrilling...
    Do you drill the hole through one board, put it up next to the other one the way you want them lined up, stick the bit through the hole u just made, then drill into the second one and make the hole?
  7. eazy
    eazy Full Member
    and what kind of caulk?
  8. aznboi3644
    Well...I get a tape measure and mark off all the points...then I get a right angle ruler and mark off 3/8's inch from the edge so the screws will be centered in the MDF side.
    I predrill one end then screw...predrill the other end and screw...then predrill the rest...undo everytihng and glue and screw
    I screw the ends in so the boards won't move while I'm predrilling
  9. aznboi3644
    Any caulk you want...black caulk, white caulk, yellow caulk, blue caulk...it all does the same job.
    I just get the DAP bathroom caulk in the hand sqeeze tube from Lowes. Sqeeze a small bead in the joint and then take my finger and smooth it in there
  10. eazy
    eazy Full Member
    I've got that insulating foam sealant that hardens and is air and water tight, and I've got mortor/concrete caulk.
    Will either of those work?
  11. aznboi3644
    um...I wouldn't use either..
    Dude a tube of that DAP bathroom caulk/adhesive at Lowes cost like $1.75. One sqeeze tube is enought for your enclosure. I've used it instead of wood glue also and its strong as hell.
    lol...eazy...you're making it harder than it is...but hell we're adding to the length
  12. aznboi3644
    Also today I fried one of my old school RF 10's. They are rated 150 watts rms a piece and I was givin em 800 watts rms total. Only one is working now.
    I was driving home from work and had it up a little higher than normal...than the bass suddenly got like half as loud...I was like damn I f u ck ing fried one...came home and looked at it...locked up like there's no tomorrow. lol
    I was gonna give em to my bro for christmas. Welp looks like I gotta get him something else now
  13. eazy
    eazy Full Member
    Ah ****, I left for the hardware store before you replied...they were going to close. The guy at the hardware store told me to use 100% silicone.
  14. TheViking
    100% silicone will work perfect!
  15. pedro quiroga
    yeah i use silicone for EVERYTHING.works great.
  16. eazy
    eazy Full Member
    Oh....well in that case I'm good lol. I got wood glue and the 3M spray glue too.
  17. eazy
    eazy Full Member
    All I have left to get is carpet and maybe some connectors for the end of the wire.
  18. aznboi3644
    I don't like using a caulk gun cuz you can't get all the joints
  19. eazy
    eazy Full Member
    I got two cracks near the ends of the MDF like this...
    What am I doing wrong? Am I not predrilling deep enough or something?
  20. eazy
    eazy Full Member
    Well that's what it was, I wasn't predrilling deep enough. All the rest of the holes were fine. I attached the bottom, left and right side, and put the port together...but didn't attach it to the bottom yet.
    (bottom face up)
    (bottom face up again)
    (front, top, and port not attached yet)
    (two port pieces attached, but not attached to bottom yet)
