/ Register
Just a Suggestion
Discussion in 'Car Stereo Speakers' started by Ranger SVO, Jan 3, 2008.
  1. Ranger SVO
    You know the right values for the 12dB/octave at 6000 Hz
    For the 18dB/octave C1 = 5.6 microfarad and C2 should be 16 microfarad
    The coil L1 = 0.1mH. This will be a 5000Hz crossover.
  2. aznboi3644
    ahh I see now...thank you
  3. kcox669live
    kcox669live Full Member
    Hey ranger, what is the small yellow component in your crossover exactly? I've only seen it one other time and I think they called it tweeter protection.
    How does it work?
  4. Ranger SVO
    Its a small ceramic capacitor. Sometimes when we use cheaper quality caps there can be some leakage. Adding a series capacitors "removes" the effect of leakage inductance. Choosing better quality components don't need fixes like this. Also smaller cap values don't have this problem. So in that circuit, it was completely not necessary.
    Another way to prevent a problem is to use two 99uf in parallel instead of a single 199uf. Small value caps have much less problems than large values.
