Good HT receiver
Discussion in 'Home Audio Talk' started by cccullen, Apr 23, 2008.
  1. electrolytic
    electrolytic Full Member
    Ya, don't mess with karaoke through surround sound or home systems, bad things happen lol. Get something like this, its 200 watts and that's tons when it comes to a live signal, plus you have all kinds of extras, can plug in extra mics, 6 or 8 tracks i think. There's lot's too choose from there anyways. You can plug in your karaoke machine too but just use it for the music output and sing through the mixer/amp.
    Phonic Powerpod 620 Plus / S710 PA System $299.99
    Buy Phonic Powerpod 620 Plus / S710 PA System online at Musician's Friend
    Here's the main page with all of them..
    Buy live sound packages, PA systems, portable PA systems, portable sound systems, speaker packages online.
    Phonic Powerpod 620 Plus / S710 PA System Specifications:
    Powerpod 620 Plus
    Product Dimensions: 1.18' x 1.28' x 1.87'
    Shipping Weight: 29.8 lbs.
    S710
    Power handling: 160 W (Peak); 80W (Program)
    Frequency response: 65 Hz - 20 kHz
    High sound pressure level: 96 dB SPL @ 1W / 1M
    8 Ohm nominal load
    Phonic Powerpod 620 Plus / S710 PA System Features:
    Powerpod 620 Plus
    100W + 100W @ 4 Ohms stereo power amplifier for Main L/R or Main/Monitor (Bridge mono, 200W @ 8 Ohms)
    32 - 40-bit digital multi-effect processor with 100 programs plus foot switch jack
    Six balanced Mic inputs and eight Line inputs
    Two Super Hi-Z inputs optimized for direct instrument input
    2-band channel EQ
    7-band graphic EQ
    Pad control on channels 1~4
    AUX input
    Stereo RCA I/O
    +48V phantom power
    Built-in limiters
    Monitor and effect sends on each input channel
    Drive level / Effect out master control to the input of built-in effect processor
    Wooden case with carpet covering, plus steel corner protection
    S710 10" 2-way Speaker
    Use as a floor monitor or mounted as a raised sound reinforcement speaker
    10" heavy-duty woofer and piezo tweeter
    Built-in handle
    Dual 1/4" phone jacks
    35 mm stand adapter built-in
    Add this PA package to your cart, and start playing gigs!
  2. cccullen
    We already have a mixer but you all are right about the speakers, I'm with you on that. i went and looked at some BMB speakers, they sounded really good so I guess i'm going to buy it for my father today. It looks like the problem is solved. I also found out that the receiver my dad has now can take a Ipod dock so he doesn't even have to change the receiver.
    Thanks for all your help..
  3. electrolytic
    Nice!! Here's one 450 watts lol oop that's max. Still cool.
    Better Music Builder BMB CS-500V 10" 450 Watts Double Magnet Karaoke Speakers & Stands (Pair)
    Better Music Builder CS-500V Professional 450 Watts Karaoke Vocal Speakers (Pair)
    BMB CS-500V
    Specifications
    Type: 2-way, 3-speaker Bass-Reflex Type
    Attractive three-dimensional curved design
    Speaker: 25cm cone-type (Woofer) 7.7cm cone-type (Tweeter)
    Frequency Range: 40Hz-20kHz Rated Sensitivity: 90dB Max.
    Normal Input Power: 150 Watts
    Maximum Input power Input: 500W Each for greater output requirement.
    Max Watts: 450W
    Normal Impedance: 8 Ohm
    Crossover Frequency: 1200 Hz
    LF Low-Pass Slope: -6 dB/Oct
    HF High-Pass: -12 dB/Oct
    Voice Coil (mm): 51 dia.
    Magnet Weight (g): 1290 (Double Magnet)
    Net Weight: 10.8 Kg (24 lbs) Each
    Nominal Impedance: 8 ohms
    Dimension (WxHxD): 501(W)x291(H)x286(D)mm
    Recommended Usage: Home, Club and Bar that requires greater Output
  4. cccullen
    Those are the exact ones I looked at. I also looked at this brand called B Pro. They sound almost just as good as the BMB's. Very good lows and clean highs. I'm going to call the owner of the place (my dad has bought a lot of stuff from this guy) and try get the price lower.
    He wants about $700 for the BMB's and $500 for the B Pro's. ouch!!!
  5. electrolytic
    whoa, hold on, its $399.00 at that link i posted for the BMB lol
  6. electrolytic
  7. cccullen
    yeah electro. My father got 2 of those Ipod docks, He bought another Onkyo amp and bought some Bpro speakers for the Karaoke.
  8. electrolytic
    Sweet! Your all set, bring in some drums and a couple guitars lol.
  9. cccullen
    lol. I'm just waiting for the ipod docks and the amp to come back then it will be all set up.
    I'll take some pics once it's done and some pics of his HT set up.
