Cutlass
Discussion in 'General Car Audio Discussions' started by jonnyv713, Aug 16, 2008.
  1. pedro quiroga
    nice! 2 of those and 2 8's in back and boom your set!
  2. jonnyv713
    I was working on my box designing skills out and came up with this. I believe it is ABOUT 4.5 after port displacement and tuned to ABOUT 28Hz. What do you guys think of it?
    Box designers: Is the port area too much? I don't want it too big do I? Because if it is, then the woofers wont be able to load it, right? I'm not for sure on that, its just something i thought i heard.
  3. jonnyv713
    also, i found this strange. i used an online bandpass calculator and i entere the parameters for my 13kv.2 and this is what i got as results. wierd??
    Lower 3db Rolloff: 25.00 Hz (F3 Provided by user)
    High 3db Rolloff: 91.30 Hz (Calculated)
    Sealed Box: 1.45 cubic feet
    = 2509.34 cubic inches
    = 41.13 liters
    Ported Box: 0.79 cubic feet
    = 1367.47 cubic inches
    = 22.41 liters
    Tuning Frequency: 47.78 Hz
  4. pedro quiroga
    i like the looks of that box. does it matter were the subs sit? i mean what if you had them closer to the port so they load the same.
    have you ever tried to kerf cut?
  5. jonnyv713
    What kind of wood is really light? BUT I can still make work for building a box...
  6. pedro quiroga
    i hear birch is light and strong to boot.
  7. jonnyv713
    What do you guys think of the IA 187's? I was thinking of purchasing 4 of the 12" versions and powering them off a Audiopipe 30001D. I heard that at 750RMS they really shine.
    Im also open to any other suggestions of subs that will work good in my application.
    Also, what happened to Mach 5 Audio? Are they still going to continue to sell equipment?
    Thanks guys.
    http://www.soundsolutionsaudio.com/store/products/12"-187-Series.html
  8. pedro quiroga
    i was looking at them too, but isnt 750 rms too much for them? i mean they are rated at 300 rms.
  9. jonnyv713
    i read somewhere that a guy did testing and you need to ATLEAST double the RMS. At 750 each they really shined.
  10. jonnyv713
    Power handling is insanely underrated. 300 watts is childs play to these subs. With a small sealed enclosure, you could easily attach one to between 800 and 1000 watts RMS. Trying this is your own risk, don't complain to me if you kill one. I have run mine with 250, 350, and 750 watts RMS to each sub. At 250, they'll get loud, but not much for DD volume levels. 350 is an improvement. At 750 they shine. To say the least, you'll need at least double their recommended power rating to see what these subs are capable of.
  11. pedro quiroga
    i should ask my bud robin. he runs IA and is sponsered and would deff know the answer.
    he gave me a good price on 2 of the 15's once. maybe 3 10's in my truck will pound nicely on the 1900 watt amp i plan to buy.
    its going to be a DB drive amp..thier 1900 watt mono amp. hope it does close to that.
  12. jonnyv713
    What is this thing?!?!
  13. jonnyv713
    No one?! Ok, well its the beginning of Lila's new substage!!!
  14. jonnyv713
    We made another step today in 6th period World Geography! haha
    here it is 9cu.ft. @ ~30Hz. Should be pretty loud. Losin the backseats this time around too
  15. Lazy Eye
    Lazy Eye Full Member
    is this for the 13Kv.2's?
  16. jonnyv713
    I'm thinkin those for a lil bit, then I will either use the cheapo hifonics subs or some different ones. idk for sure yet. I know i am building it though. Birch this time too.
  17. Lazy Eye
    sweet...
    I've been thinking about getting a ****load of hifonics 12's since they're only like $30 each and just building a pretty big set up with em'
  18. jonnyv713
  19. pedro quiroga
    the 187's will work ,but the power should be kept near the rms. my bud said 750 each would fry them.
    the mack5's i hear are low end monsters. did you see the rec tuning....15HZ!! wow that would kill the lows.
