Big ?
Discussion in 'Car Stereo Amplifiers' started by treitrei, Jul 24, 2007.
  1. danracer
    danracer Full Member
    how many amps are the high output alt. rated??
    they vary from 130ish to 300+ amps
  3. danracer
    is 110amps good??
  4. pedro quiroga
    what kind of car?my truck has a 105 as stock.
    can you go bigger?
  5. danracer
    well i have a minivan...Nissan Quest
  6. pedro quiroga
    maybe a 130 or 170amp?
    do the biggest you can afford
  7. danracer
    can the stock amp be modded to make it more amps??
  8. pedro quiroga
    i think so,but it might be better to get a stonger one instead.
  9. danracer
    ohh...im not having electrical problems yet but in case of i wanted to know how many amps would be good....I ha another question....can i pus a resistor on an amp so it reads the 4 ohms that is supposed to see when bridged??
  10. G3n3R@1
    G3n3R@1 Full Member
    i believe so, not 100% sure but if u can i'm sure you need a hefty one.
  11. danracer
    ohh its that i need it to see the 4ohm load cause right now it has .866 and i dont want to **** up the amp
  12. pedro quiroga
    what are you running?
    details please.
  13. danracer
    okk...yesterday i putted on the old amp, i had for the subs, but now they are for the speakers...i have conected 4 6x8 kenwood...4 ohms each, conected in parallel...and i have 2 4 inches sony, also 4 ohms each....the old amp is a profile baja 1000 watts 2 channels, bridged and needs a min. of 4 ohms. the total impedance of all the speakers together is .66667
  14. aznboi3644
    adding a resister will not make your system any louder...the resistor will just absorb the added outputed power in heat.
    Never use resistors to change the impedance cuz I won't help or work
  15. danracer
    what would be the best thing to do then??
  16. danracer
    besides wiring it differently
  17. aznboi3644
    getting a different amp....why do you have so many interior speakers?
  18. danracer
    ohh crap...well i really have four on my van and had 2 4 inches around my house and desided to put them on...i guess ill have to wire 2 6x8 per channel and forget about the 4 in
  19. aznboi3644
    I wouldn't use those 4 inchers...you could make some work shop/garage speakers outta em.
  20. danracer
    yeah just disconected the 2 4 inchers and left the amp with 2 ohms per channel doesnt sound as hard as when it was bridged but still sounds a lot harder than before...what would you guys think it would be best? build a custom vented box for my 2 15 audiopipes or get rid of the audiopipes and go with some kicker cvr's or some MTX's??
