Big ?
Discussion in 'Car Stereo Amplifiers' started by treitrei, Jul 24, 2007.
  1. treitrei
    treitrei Full Member
    yea are they difficult to install by yourself
    depends on your vehicle.
  3. danracer
    danracer Full Member
    i dont have one because of that and because i need to do mods to make it fit in my van and im too lazy to do it...lol
  4. treitrei
    lol. but i have a jeep grand cherokee '94
  5. danracer
    you have to check online to see if it fits if it doesnt you need to make mods
  6. treitrei
    where do i go to do that
  7. danracer
    there you go to the battery search and find your car
  8. treitrei
    cool thanks it says i need hieght adaptors, so do i place it near my subs
  9. danracer
    the height adaptors are for the engine bay...for the back you should use a deep cycle one and you shold put it in a battery enclosure
  10. treitrei
    a deep cycle battery? what color. yellow??
  11. danracer
    in optima yes yellow
  12. treitrei
    okay you help a whole lot but i have one more ? i think bass blockers are they simple to install?
  13. danracer
    they should be simple because they go in the speaker wire
  14. treitrei
    k thanks for all your help
  15. danracer
    no problem ;)
  16. aznboi3644
    If you are having electrical problem with that amp that puts out around 300-400 REAL watts than upgrading your amp will only make the problem worse...I would highly recommend start looking for a new High Output Alternator if your car is having trouble keeping the battery charged with such a small amp as that.
    Also this combo of subs and amps are total opposites....such quality subwoofers vs. such a cheap amp.
    I would recommend that you sell those subs...you don't have the electrical or power to push those subs...they are just power hogs and don't use low power as effectively as other lower power subs. a 5000 watt sub just isn't going to be as efficient as a good 500 watt sub.
    Spend the money that you make on selling the subs and amp to upgrade your electrical first....must have power to make power
  17. pedro quiroga
    what azn said is the truth.you first have to upgrade your elecrical system.even if its just a big 3.
    adding second batts to an already weak set up will only make things worse.
    do the big 3 first and see what happens.
