ok i took some measurements today and i designed an enclosure for behind the seat for the RF above it will be roughly 1.24685 cubes
Rockford Punch series subs suck balls....HORRIBLY. The build quality on them is flea market crap. I'd buy Lanzar subs before RF Punch subs
or this one Phoenix Gold Ryval V12D - 12" Ryval Series Subwoofer • 600W Max • 150W RMS • Laminate-treated paper cone • High excursion triple layer UV-treated foam surround • Rigid powder coated steel frame • 1.5" Dual 4 ohms voice coil - , Component Subwoofers,
rf sucks cept for their power series. I'd use that Coustic sub before that PG sub...I dunno but i don't like its look
k well i might just use one of those ehqs 12s that i have and use like a power acoustic 340 or 460 and just turn it down a bit unless it might hurt the sub
i just did a 1.56cuft sealed box, 15"x15" cube for a ehqs12 in my moms trunk runnin of a little jensen amp and it hits pretty well. better than the kickers10d and kenwood10" i had in it before combined. plays late nite tip quite well but doesn't quite dig low enough for white girl or hypnotize. I suppose if it had proper wattage it might though. sounds nice as well.
ok i think today i am going to order the amp and i was jus lookin at this y is it so cheap and is it good ** CLOSEOUT! ** MA Audio M600XE - 2-Channel High Performance Amplifier • 175W x 2 chan. @ 4 Ohms • 350W x 2 chan. @ 2 Ohms • Full MOSFET Circuitry • High/Low Level Inputs • Variable High/Low Pass Crossover 50 - 250 Hz - , Car Amplifiers, 2-Channel Am
much rather suggest this Power Acoustik PS2-800 - 4 ohms: 150 watts x 2 • 2 ohms: 180 watts x 2 • Bridged, 4 ohms: 360 watts x 1 • PWM MOSFET power supply • High or low level inputs with floating ground • Tri-mode capable • Includes remote level control knob • Frequency Resp
its a single 2 and ya i know i cant bridge it and i should have a class d but i was just gonna use one channel for now or i might build an enclosure for all the way across the back
