ok im istalling my zues z4000. everything is going well, im using all moster cables... but i have one major problem. when ever i put the fuse in the amp or attach the posotive cable from the battery, it blows the fuse. the ground cables is fine, everything is good, but the fuse goes instantly... we think that it way just be the amp... any suggestions would be appreciated.
the powersupply in the amp could definally be bad. Try Disconnecting the Neg Battery Termanal (at the Battery) then hook EVERYTHING up after that reattach the neg terminal to the battery this is a good habit regaurdless of your problem, you should NEVER hook electronics up to live power sources
