im sure its more like 375w. They rate is low at 4ohm so you can get into lower classes in comps. Are you planning on running one at 4ohm?
Can someone fix the title of the thread? I'm going to run it at 1 ohm most likely, I was just curious though. Depends how the amps do one my electrical system for daily driving...
LMAooo i was not, i told you that it would put out more than 50 watts, it was a cheater amp, and i think i said between 300 and 400 probably, not sure though.... syn = :bs:
