Yes or No question?
Discussion in 'Car Subwoofers' started by Johnson450, Feb 3, 2010.
  1. Johnson450
    Johnson450 Member
    Finally realized what im putting in for subs. Its a hifonics 10 inch 1000w 4ohm sub with a RMS of 500. Following that Ive chosen a Hifonics 1200w amp that puts out 450 at 4ohm 900 at 2ohm and 1200 at 1ohm. Is the amp perfect for the sub?
  2. Kvo_8
    Kvo_8 Full Member
  3. Johnson450
    Johnson450 Member
    well i plan on ordering that probably tomo becuase ive been told all i need is a ten inch for my truck. Thats the sub but im clueless on what i need for an amp. If u could help me out if would be very much appreciated. An based on if its the dual 4 ohm or the 2 ohm im not sure, what would be a better choice?
  4. Kvo_8
    Kvo_8 Full Member
    what truck do you have? also is it an ext cab?
  5. Johnson450
    Johnson450 Member
    its a 2006 f250 with the back seats but not the two full doors
  6. Kvo_8
    Kvo_8 Full Member
    well, dont worry too much about what everyone is saying what you need. it comes down to what you want. are you looking just to add some low-end in your music or are you looking for some mirror shaking bass for your truck? your budget is also a big factor.
  7. Johnson450
    Johnson450 Member
    Some mirror shaking bass
  8. Lazy Eye
    Lazy Eye Full Member
    How much is your budget for both the subs and amp?
  9. Johnson450
    Johnson450 Member
    for sub/subs and amp together 200-350 preferably low
