i have a 2 channel amp and two 4 ohm dual voice coil subs..how do i properly wire the subs to the amp?
I'm going to assume that you can bridge the amp,so heres what I came up with: http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=4 Choose option 2 and bridge the amp.
I was also looking at this diagrahm.. http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_4-ohm_2ch.jpg
That would also work,but you didn't list the model # or the specs for your amp.There are some cheaper amps that are not 2 ohm stable at all,so either way is possible.
