wiring code
Discussion in 'Off Topic Discussion' started by toid, Mar 27, 2002.
  1. toid
    toid Full Member
    A guy brought me a 91 civic...the wiring harness was cut from the car. I need the wiring code to wire in a deck. Where can I find this wiring code?....What color wire is what...Any of you guys know?
    Thanks
    toid
  2. musthavemuzk
    musthavemuzk Full Member
    try www.installdr.com
    might be something there to help.
    can mayb try www.metraonline.com
    might be tricky either way.
    i do have a Q though....are you just needing the color for power and ground or all the speak wires too?
    if you are going aftermarket systme then it would be best to just run new wires for all the speaks as the factory are kinda wimpy.
    can run ground and power direct if needed.
    just some thoughts.
    Monty
  3. toid
    toid Full Member
    I've got it...someone e-mailed it to me.
    the guy is a used car salesman and he just wants a cheap deck in there. To run new wires would be a bit more than i'm willing to do, since it's going into the doors in the front...aggravating if someone can give me a quick code.
    Funny, it's a Piece of shit car ....but I looked in the doors... some NICE Boston Acoustic coax drivers...too sweet. Ironic isn't it?
