Wiring 2 amps
Discussion in 'Car Stereo Amplifiers' started by tippmann7, May 11, 2010.
  1. tippmann7
    tippmann7 Full Member
    Im looking at wiring 2 amps, 2 planet audio anarchy mono blocks at 700rms, to 2 planet audio big bangs, 600rms. i already have a capacitor that i would like to install but what i am unsure about is do i install the cap before the distribution block for the amps? or do i need 2, 1 after the block for 1 amp and 1 for the other?
  2. fstrfvo
    fstrfvo Full Member
    you can install it before the block just to make wiring to the amps easier, try to make it as close to the amps as possible. Just make sure you have the power wire fused near the battery. A cap will not make up for a weak or damaged electrical system though.
