What should the wire thickness be from the inside of teh box to the sub. I found out that there is a difference and it's only one wire. My subs are DVC and one sub has one diverent wire for the bridged part, and it hits harder then the other sub. What should the wire gauge be inside the box so I can re wire it for louder bass. So box to sub wire thickness?
Have you ever tried different? I posted this on another site and they didn't understand me. This wire on this diagram is like probably 1 - 3 gauges thicker and you can definitely tell it's hitting harder.
is it the new one??? maybe it isn't broken in as much as your older one recheck how the subs are wired....i'd undo all the sub wiring then rewire them
Yea it's the new one, It's been installed for like 18 days now. I'll check the wiring and probably rewire it.
