I can't decide what tuning to go with, i have 6.6 cubic feet box with two 6" ports. The pink line is 31 hz and the white line is 39 hz. Can someone explain to me what the difference will be and why? lol pretty please...
ok, is that it? the bass won't sound different? So i should go as low as possible? like say 30 hz or I can go right down to 20 hz i think, cone excursion is not a problem
tuning??? tuning anything below 30Hz will gain some low end but sacrifice some higher bass notes and basically is worthless unless you are playing 20Hz tones all day long. Difference is negligible...either will work. Depends if port length is a factor
