will this work
Discussion in 'General Car Audio Discussions' started by mrknownothing, Oct 20, 2008.
  1. mrknownothing
    mrknownothing Full Member
    will this amp work good for these to 15" subs
    Brand: Lanzar
    Condition: Factory Refurbished
    Description
    2 x 1000 Watts RMS at 4 Ohms
    2 x 2000 Watts Max at 4 Ohms
    1 x 4000 Watts Max at 4 Ohms Bridged
    2 x 1650 Watts at 2 Ohms RMS
    Electronic Crossover Network
    Bass Boost Circuit
    Variable Phase Shift Control
    2 Ohms Stereo Stable
    Anti-Thump Turn-On
    Soft Turn On/Off
    High & Low Level Inputs
    Blue Light Illuminated Crossover Control
    Power & Protection LED Indicators
    Advanced Protection Circuitry
    Bass Boost Remote Control
    T.H.D: 0.04%
    S/N Ratio: 90dB
    Channel Separation: 65dB
    Frequency Response: 15Hz- 35kHz
    Dimensions: 10.47''W x 2.46''H x 21''L
    kicker c15comp
    15" Comp series subwoofer
    4 Ohm Impedance
    250 watts RMS / 500 watts Peak power
    Injection-molded polymineral cone
    Ultra length voice coil
    High temp voice coil former
    Rear cone brace
    Polyfoam ribbed surround - double stitched
    Marine ready
    Nickel Plated Terminals
    Frequency Response: 25-500 Hz
  2. mrknownothing
    plus
    PHOENIX GOLD RSD-5CS RSD SERIES "5.25" 240 WATT COMPONENT CAR SPEAKERS (120 WATTS EACH)are these good..ok..or really good 240 WATTS TOTAL OUTPUT
    120 watts output each
    120 watts total RMS rated
    60 watts RMS each
    Sensitivity: 86 dB
    Frequency response: 65-20000 Hz
    RSD series (best series out by Phoenix Gold)
    5-1/4" 2-way Component System
    Injection Molded Cone
    Aluminum Plated Polypropylene Cone
    Butyl Rubber Surrounds
    Rigid Powder Coated Steel Frame
    Interwoven Tinsel Leads
    Optimized Magnet/Motor Structure
    Priced per pair
    Impedance: 4 Ohms
    CAD/CAE Performance Design
  3. cccullen
    the Phoenix gold speakers are good but they are not 120watts. they are 60watts RMS. the 120watts is MAX, you shouldn't pay any attention to that.
    Please do not buy a lanzar. they don't make good amps. if you are going to get 2 kicker comp 15' subs then you'll only need an amp that puts out 500 watts RMS. what's your budget for your amp?
  4. mrknownothing
    no budget so what do u suggest
  5. cccullen
    what kind of sound do you want to achieve? everybody has a budget, if you're going to let me go wild then i could suggest stuff that you'll be spending thousands and thousands of dollars. don't think you'd want to spend that much...
    How many amps are you looking for? one for the speakers up front and one for the subs?
    Do you want to keep the brands of the amps the same?
    What kind of car is it going in?
    what kind of box are you going to use for the subs? sealed? ported?
  6. pedro quiroga
    hmmmmm no budget constraints. wish i could do that.
    CC is right your amp cant be more than 500 watts total 600 max.
    the make of the vehicle is key to knowing the size the box can be, and how much space you are willing to sacrifice for it. ported boxes for 15's will need to be huge.
  7. mrknownothing
    ok well those are just for those to speakers..i already have a full system im gettin from a family member with amp and 2 boss 15"s i have a 98 expedition..i dont know about the box n stuff i have a brother dats goin to hook everything up i just want to know good products to buy but uhhh.....i would say 500 dollas left since i have the other stuff which all i need is a amp for the two kickers n some door speakers
  8. cccullen
    first off, i would trash the boss 15's. what kind of amp are you getting from your family member? I'm assuming the amp your getting from you family is for the front speakers? I just want to make sure that it has enough power for your front speakers.
    500 for the subs and amp and the door speakers can be done without any problems. Are you willing to buy off of ebay?
    Is your heart set on the kicker comps or would you be willing to step it up to some kicker CVR 15"?
    http://cgi.ebay.com/2-KICKER-CVR15-D4-15-CAR-SUB-WOOFERS-CVR-2000-WATT-NEW_W0QQitemZ140275950725QQcmdZViewItem?hash=item140275950725&_trkparms=72%3A1205|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
    http://cgi.ebay.com/HIFONICS-BRUTUS-BXI-1208D-MONO-CAR-AMP-BXI1208D-BXI-NEW_W0QQitemZ150300802384QQcmdZViewItem?hash=item150300802384&_trkparms=72%3A1205|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
    this stuff plus your PG RSD's up front come up to almost an even $500.
  9. cccullen
